Strippin chrome
Denver, CO
Thinkin about stripping or sanding the chrome plating off my grill and surrounding trim in order for a new coat of paint
What is the best method to remove chrome plating
Don't try to remove it. Just prep with Scotch Brite, apply a self-etching primer and paint. The primer and paint can be purchased anywhere in the rattle cans.
We've have used the Rust-oleum Graphite wheel paint with great success.
^^x2
Does anyone know of an easy way to remove it? I'm all for painting over it but I have chrome flaking in places. painting over would look half a$$ in my situation.
A spray-on, foaming oven cleaner is often recommended. Spray it on, let it sit for 20 minutes or so, then remove the cleaner and chrome with a relatively soft brush and some soapy water. It shouldn't harm the plastic.
you have to make sure it is the right oven cleaner too. The Easy-off in the yellow can contains Sodium Hydroxide. This will eat the chrome.
The stuff in the blue can won't touch the chrome, but it really good for removing grease/oil.
Also, be careful with this stuff. It will remove chrome, skin and sight if you're not protected.
I have also found that regular clorox bleach will work too if you don't mind letting it soak a while.
Another option is to buy a replacement grille. Or do the Satoshi mod.
Golgo13, thanks for clarifying which oven cleaner is needed.
Sodium hydroxide is Soda Lye- as used in making old soap. Think I have seen other spray on degreasers that use it too. My generic oven cleaner contains it. I believe if you look certain drain cleaners for grease and hair use it also.
Forbid crystal drain cleaner is 100% sodium hydroxide. Many people use it for making their own soap. It is available in a lot of hardware stores. Really easy to find in areas with sceptic tanks
OK, that will take if off the plastic, but what about wheels? And if I do it in the driveway, is it going to eat my concrete also?
This is the first I've heard this route. I've spoke to chrome platers, and they won't typically de-chrome parts, although it is well within their capability.
Doubt it hurts concrete-ACID eats concrete this is base. Test out on a spot. Flush it away
Just did a Google search on that one and NOOOOO don't do the wheels with it. Sodium hydroxide and aluminum basically melts the aluminum and releases hydrogen gas, so, if you DON'T like your wheels, cover them with sodium hydroxide and they will melt off the truck.......
What chrome are you trying to strip off the aluminum wheels? There is no chrome on OE wheels unless you have the chrome steelies. Some aftermarket aluminum wheels are chromed, but that usually doesn't last too long.
If you're trying to strip the paint, try Xylene. Or some kind of aircraft paint stripper. It will be messy and gunky. Soda, Bead or Sand blasting is best to strip an aluminum wheel.
Good point....I forgot my basic chemistry.....
Ahhhh, BUT I have the elusive and hated CHROME PACKAGE! Only available in 1996, the port (or dealer) had the alloy wheels chromed, the brush guard (damage multiplier) was chromed, the mirrors and door handles were all chromed.
My PO hit a guard rail and destroyed one wheel, so I have (3) peeling chrome rims and (2) OEM alloy rims. Chromers will NOT re-chrome peeling wheels due to the pitting that has taken place due to road salts and everything that has damaged the wheels due to structural limitations.
I love the factory OEM and I WANT the chrome wheels, it's just NOT practical. By the time I buy a replacement set of wheels, then have them chromed, I will have 20 YO wheels that cost me more than a NEW set. SO, I figured I would strip the rims, and paint them with the wheel paint that seems so popular.
Why couldn't you do what @SUMMIT CRUISERS said to do at the top. If there is any flaking you could sand out the edges to make it smooth. Scoth Brite pad. Then self etching primer. Wheel paint.
From personal experience the wheel paint holds up very well. I did it. I washed my wheels with Dawn dish soap to get any grease off them. Wiped them with MEK. Then sprayed them with Rustoleum Matte Black wheel paint. That was 3 years ago. I washed them and resprayed them this winter because there were a few scratches from moving the weights. Look like new. I've used two cans (maybe three) total. At a cost of $5-6/can.
@BILT4ME can you please post pictures of these peeling chrome wheels? I've never seen such an animal.
blkproj80 is also correct, there are some decent "chrome" paints available by powdercoat. also check out http://www.g-chrome.com/ try their contact page and see if they can find you a local dealer for their product.
This is your best bet. You could use muriatic acid to remove the chrome finish but you would still have copper and nickel, you could use hydroflouric acid to pull the nickel but you would probably be dead because hydroflouric acid is the scariest crap and not a lot can be done for you if you get it on your skin. So scuff the chrome up with a scotchbright pad, sand the rough areas smooth and then rattle can them and be happy you didn't kill yourself.
I have painted a good number of wheels of late. The easiest way to do this is to jack up the car, deflate the tire and then slip index cards between the wheel and the tire beed to protect the tire from paint. Prime, paint and pull cards and move to the next wheel. I don't even pull the wheels off the car anymore. I stuff some rags inside the openings of the wheel to protect the caliper/rotor. Tape around the valve stem.
Dang, that's fancy! I just sprayed the wheels and wiped off the tires if I got any on them. But I used matte black so you couldn't really see it anyway. :meh:
