Stripped drive flange studs
Anyone have an opinion (based on experience) on how many stripped drive flange studs you can drive with, if any at all, before they can be replaced on an FZJ80? ie: is one too many, two mean certain death, etc? I have at least one that I am sure of on my PS front.
I know the book answer; replace them immediately, however, none are in stock locally and I plan on going out of town, tomorrow.
I believe if you drive with the center diff locked you should be ok for a while, Im not sure if it will lead to further damage. However if your DF is stripped then its more that likely that the outer shaft of you birf is stripped too and would need to be replaced.
They usually don't do this unless the whole assembly is loose and the pins are wobbling in their holes. At a minimum, check to see the remaining 5 are snug and tight.
Yes, a few studs (bolt part) are partially stripped, but they tighten up, one just spins round and round. This was a SEA-S special. ie:I'm in a hurry, gettting ready for a 3500 mile trip, getting my tires rotated, no time, and they can check/tighten the wheel bearings while I am doing something else. Then comes the surprise when the mechanic calls me back to show me what he "found" after using a pneumatic impact wrench/nut driver. I was all over those flanges just a week ago, and nothing was loose. He stripped them but wouldn't own up to it.
I can't say that it's a safe thing to do, but I drove with a few of mine stripped for a few weeks. I just replaced them this weekend.
I still have them off, since I'm now waiting for new rotors, and I'm probably going to replace the studs with bolts. M8 x 1.25.
Should make removing the flange a whole lot easier next time.
Thanks all, will check them to see what is tight and what isn't. The bolts idea sounds like it will solve the problem of stripped studs or nuts, but wonder why Mr Toyota didn't use bolts? ie: is it better to strip a nut or stud than something more important?
I am getting a lot of rumbling vibration, separate from the stud issue, still not sure what it is; driveshafts, front axle, U-joint?? The U-joints and driveshafts were tight, no slop I could detect and the joints rotated smoothly. It is however way past time to service the front axle, and who knows if it was done correctly 100K ago, and that is where I think the money is. It sounds almost like a bad muffler, but it is only under load. If I coast and rev the engine; no noise or vibration; put it back in gear, and give it a little pedal; rumbly noise/vibration almost like a muffler going bad, but fairly significant. Might just park it and drive something else for the Holidays.
... but wonder why Mr Toyota didn't use bolts? ie: is it better to strip a nut or stud than something more important?
The stud/cone washer setup makes a much stronger connection than bolts would. I wouldn't have a problem with driving it around on the street with a couple of them loose, but wouldn't wheel it. If your worried about it, just remove the front drive shaft, lock the CDL and drive.
Sounds like a bearing going bad. The ones that i would suspect are u-joints, tranfer and diff bearings. Lock the CDL, drop the drive shafts one at a time and test drive with only one in, this will show which end the problem is in. Also drive shaft problems are much easier felt, detected with them off of the truck.
I meant using the cone washer, washer and then the bolt.
Speaking of which, as I put on new rotors today I stripped a handful of flange studs again. These were new, from Cdan, the same design as the old ones. I even lowered my torque wrench to 20 ft-lbs instead of 26.
I had bought replacement bolts from OSH, but they were about 1/8" too long so I had to use the studs. Looks like I'll be doing it all over again. I'll find bolts that are the right length.
have you tried a new nut? The stripped part might not be entirely the stud and a new nut might hold you over. But I wouldn't hesitate to drive with only 5 holding the flange on.
You're right about this to an extent. The nuts do get mangled, some of my old ones were. So I replaced them with new ones from OSH. I think the problem with the studs is the method in which the cone washers have to be removed. The FSM shows hitting the stud head on with a brass drift and hammer.
I managed to crack a few when I first did mine.
Then there's missing the stud head on. You'll probably catch a thread and deform it. Some even suggest leaving the nut on, but if you catch the nut from a missed blow, you'll mess something up.
Using a bolt seems like a good idea. I don't see how it wouldn't work.
Of course another solution is to tap the threads a little to ensure they're not deformed before you re-install.
Thanks all; had the studs replaced today while traveling; stopped at a dealer along the way; no problem with that, the mechanic replaced the studs and nuts. The other problem he "found" was a stuck caliper piston; got another thread about this just started.
I was hoping to put this all off for a couple of months and do it all at once, and only once when I serviced the front axle; not piecemeal, but time is catching up with me.
I will also drop the driveshafts and see what I find, once the holidays are over and everything settles back down.
