Strange starting situation
DocuDude
Took me 10 years to find this space
Los Angeles
For the past 2 months, every once in a while (hot or cold start) I will turn the key and nothing will happen. No noise, nothing.
I will wait a few seconds, re-turn the key to start the car, and she will start like a charm, no problem.
Is it the starter, something else? Happen to you>
Thanks
I had the same issue on another vehicle I used to own. With no noise it would tell me it is the starter.
Good Luck
Sounds suspiciously like starter contacts, very common failure, look in the faq for repair procedure. Fix it before you burn down your truck.
It could be the starter contacts. It could also be the starter solenoid. Then again, it could be your ignition switch.
I'd start with replacing the starter contacts.
