Strange Electrical issue - HELP!
Kelowna, BC Canada
94-FZJ. I have been having some starter issues lately - I sometimes have to turn the ingition on a few times before the starter will kick in, (I hear the starter clicking when the key is turned). The other day, the problem returned, but the starter would not engage. I tried for quite a while with no success. Eventually, I ran the battery down (woops). I was able to get it going with a jump start. I took the cruiser for a run to build up a charge in the battery. The next morning, I tried to start the cruiser, with no success, not even the clicking of the starter. I gave it a jump, but a no go. The dash lights were not dimming, to me indicating that the starter was not drawing any amperage from the battery. The battery was reading approximatly 8V on the panel (obviously low). I pulled the starter, had it rebuilt (which I knew had to be done given the issues I had been having)and got it back in. Tried to start with a jump...Still nothing.
NOW THIS IS THE STRANGE PART- every time I turn the ingition, or open the door, the 4 way flashers, and instrument panel lighting blink for about 10 seconds. Now I am thinking maybe the drawn down battery somehow initiated the alarm/starter kill system (BTW. my alarm siren wires have been disconnected so there is no audible alarm, and never has been as long as I have owned the vehichle). I do not have the remote to deactivate the alarm if this in fact the issue. Here is what I have done so far with no success:
  • I tried the 2 turns of the ingition idea as suggested in some posts as a means to deactivate the alarm
  • disconnected the negative battery terminal
  • removed the low batery, and installed a fresh one
  • checked the codes - no errors
  • examined/cleaned the battery leads
  • checked the engine block and chassis ground connections
  • checked all fuses
  • called my local Toyota dealership and talked to the shop foreman-he had never heard of this type of issue
Any suggestions of what this might be??
Find the alarm module under the dash and disconnect the ground to it. Most of these have normally-closed relays in the starter interruptor circuit. If that works, just remove the thing, making sure to reconnect the start wire from the ignition switch.
I had another look at the connections to the starter. I uncliped the harness, cleaned both ends and re-attached, replaced the battery with a brand new ACDelco and away it went.:)
Must have been a bad connection in the harness.
Thanks for your responses!:cheers:
BTW.... Welcome to MUD :flipoff2:
