stock rack - budget flat platform
Agua Dulce, CA
any ideas on how to Macgyver the stock rack to accept a flat plywood platform for 2 bins on top?
I have searched the forum and seen some using the outside rails with additions for a rack over the existing rack.
I know I can figure a strong connection of plywood platform to the existing rack. But are the mounts strong enough to take this?
am i crazy?
yes I eventually I want a proper rack....just not in the budget.
Josh
Just so you know, the stock factory rack was only rated for a max load of 100 pounds, so be sure to keep that in mind with whatever your planning to put up there.
You might wanna search topics related to the stock rack, most aren't pretty. I have a pretty detailed posting about the lack of strength in the factory rack and it's connection to the roof....or lack thereof ?
I now see them as a roof ornament, nothing more !!!
That
point taken 100%...just needing an affirmation....my thinking was that max load was small considering the factory mounts were only in the roof metal.
Yup, I am now understanding that its worthless for real storage unless ur throwing double skis or a some body spongers on top.....
On my previous 80, when fully loaded with people heading to Lake Tahoe to ski, I would throw large/bulky soft sided clothes bags/luggage onto the roof between the rails and cross bars and then basically strap the soft bags down. The weight was spread over the roof area and really the straps just held it down. A good way to get the luggage outta the cab and about the only decent use for the rack I ever found.
OK now we are talking real deal travel here....So a few soft bags on top strapped down hard, no prob.
thanks cme4
Here are some photos of what i did with my factory rack.
img_0091-jpg.1458695
img_0093-jpg.1458696
What about just running a hitch mate to carry your firewood around ? Or, if you really want it up top, go get a moving blanket from harbor freight and lay that between the rails. Then you can carefully lay in your firewood and strap it down with a ratchet or even a cam lock strap. Just be careful not to pull it down too tight or you may dent your roof in.
Plywood is really heavy by itself. Also wind could try to lift it or push it down.
Look at the Gamaviti flat 3/4. I do understand a budget but maybe in the future. It is honestly not that much and seriously high quality. 100% best bang for your buck
Someone bought (2) aluminum ramps (to drive your lawn tractor into your pickup) from Tractor Supply (or similar) and bolted them side by side to get a full width flat rack. They square U-Bolted them to the rails on top to give themselves a "deck". It ended up being like 72" long x 60" wide. These were NOT the curved ramps.
You will spend more time and money trying to use the factory rack, just get on Craigslist and get a used Yakima or Thule tower and cross bar then put what ever you want up there.
get a HF basket in the rear tow hitch for the wood. Having all that weight above your head is not the best.
Toyota Landcruiser 1988 Diesel RHD HJ61 (fj60 fj62) 4x4 12ht 5spd
or..buy it where you burn it....I believe is what they say nowadays.
I once put some dive belts up there, kept bouncing off the roof the whole way home. 100 Pounds is pushing it. plus , it'll rattle the towers loose and show you the rusty bolts in its tower mounts. (ask me how I know)
