Stock muffler size/part # for a 79 s/b 4x4
Hi everyone,
My 1979 4x4 s/b has a lifetime muffler warranty on it from Midas. The first muffler that Midas installed on the truck was in 1986. The last time the muffler was replaced by Midas was in 1994, at which point Midas still installed their own brand mufflers. The original Midas part number was 7922.
I was told that starting in 1997 or some thereabouts Midas stopped using their own mufflers and went with other aftermarket suppliers. I stopped in the local Midas shop to inquire about the warranty, and it is still valid. If I don't have them install the muffler, they will hand me the muffler uninstalled, and the warranty will no longer be valid; which is fine with me.
The issue is that the Midas shop can't seem to find the correct muffler part number now. All they can come up with is a muffler listing for a 2wd truck. They "think" a universal muffler will be the only option, but they don't know the size.
Does anyone have a part number/brand for a non-California emissions 4x4 short bed truck? If no part number is available, do you have the correct dimensions, including the inlet/outlet pipe size for a totally stock truck? Given that my truck is not CA emissions, it does not have a cat.
Thank you,
Zack
PS: I posted this on Yotatech, but it seems that they don't have an answer.
So the Midas shop can't crawl under your rig with a tape measure and see what size they need to match? The FJ 40 never came from the factory with a s/b, so there is no listing for the right part. John
Well it is a pick up, not an FJ40. The truck is not registered or insured so I can't drive it there. The muffler on the truck is rotted badly, so there is little left to actually measure.
Zack
Oops, my bad. Been jumping around in different forums too fast. Anyway, is there enough left to just measure by yourself? OD of both entry and exit tube, length of muffler body, and whether either or both the front and rear are offset or centered. John
