Stock height medium spring?
Golden, CO
Looking to replace my sagging original springs/shocks. I have a '96 FZJ with 175k. I have a non-winch bullbar. Not looking for a lift but I'd like to get back to the original stock height (sagged over 1" in the front from what I can tell). The options for springs seem to be OEM or OME. From what I've read the OME heavies on the front will be too harsh without a winch but I'm concerned the OEM springs might not be enough. Is there a stock height medium load spring out there I'm missing? If not does anyone have experience with new OEM springs and a bull bar? Also, wondering if FJ80 springs in front might be the way to go as they are slightly taller. Any other advice?
I just installed my suspension a couple weeks ago. Dont know how stock height originally was. Rolled the dice and went with ome 851 fronts and 862 rears. Sits close to level without spacers and rides fine. I dont have any accessories though. Only removed the running boards so far. Hope that helps.
OME stock height springs with a AOE bumper up front my third row is removed as is the spare underneath and the bracket that holds it. Half a tank of gas. The ride is much better over the old stock springs that felt weak and saggy.
Edit: If I didn't plan on lifting it within the next year I would have installed a spacer up front to level it out. I'm also running 285's.
Lovely. It's firm but not rough. You really feel it when going around corners. My rig usually has a roof rack and going around corners it would list pretty badly. It's much tighter now.
Darkness, you're in CO right?
I have a set of OME stock height springs I'm looking to get rid of. Maybe these and a spacer will do you.
Since you're local and its a 5 minute job, I will let you try it out first.
I used them for about a year, stock bumpers, and decided to go with the 2.5" mediums.
I've got a winch + AUX battery up front and needed to go with beefier than OEM shock because things wouldn't dampen with all that weight. I used the OME Nitro Sport shocks. However, I bet the factory spec Tokico shocks would be a good combination without the extra weight that I have. I didn't really drive it with the OME coils and ARB on and without the winch + AUX battery to test that theory, just know the Tokicos couldn't handle the dampening the weight and the OME's did. I left the Tokicos on the rear and the odd combo of shocks has been very good to me.
I suspect something like the Nitro Sports might be kinda harsh without the weight of a winch to settle them a little, as they can be a little jarring at times in their effectiveness.
I'll bet you could get off really cheap here by going all Tokicos and taking mod5csi up on his kind offer of the slightly used 861/862 coils. The fresh coils really make a difference that shocks alone don't. Best of all, no caster correction.
That's my plan for the moment, though I may research shocks a bit more. Thanks!
I got 2" in front with the 851s.
3.5" in rear with 860s.
It is said you get .75" with the OME stock height & a firmer ride than stock.
So 851/862... level that's good to know.
I'm thinking that's like the 850/860 combo. It's seem that OME likes stink bug. I had to add a 25mm spacer to my set up of 851/860.
SNIP
I suspect that's when newly installed on the truck based on my experience. At first, yes, you'll likely get that much. After a couple of months, the coils will settle and you'll have somewhere between 3/8" and 1/2". If the used coils that were offered as potentially working for what the OP needs were in stalled, the lesser numbers will apply, since they've already been broken in.
I don't think it's so much that on OME's part as the way the ride height of coil spring suspensions is more load sensitive than other suspension methods. Many of the OME coils are noted as supplying additional carrying capacity. If you actually load on the additional weight they are indicated to carry, most of the stinkbug would be gone.
Alternatively, if you buy them for level ride on the trail on a loaded vehicle, you'll get a lot of stink bug around town unloaded. If you buy for level ride on an unladen truck, the tail will likely be dragging when you're loaded for fun in the woods or desert. The key is finding a set that is not too short when loaded, not too tall when empty, just right as Goldilocks said about the accommodations of the bears as she was rifling their house...:rolleyes:
They actually did not settle much. I did not measure when I removed them. But the .75" 'lift' is accurate. Compared to my 225k miles stock LX springs. The lift was level enough for me.
I found the ride firm, but better settled in the mountain passes. Not harsh by any means, and I think the fresh stock shocks would have been fine. I bought the Slee kit so it came with OME shocks.
I'm not a fan of the OME shocks, only because they don't handle washboard roads very well. When the time comes I will upgraded to Fox I think.
Worst case Darkness, you can add a small spacer from Slee if your bumper weighs the front down.
