stock gauges
Cloverdale B.C. Canada
Website
www.instagram.com
quick question? i did search and looked didn't find much ,i have decided to switch back to my factory gauges using a small block chev . do i need to order the adapters to put the factory sending units into the chevy . or is there any other options out there . i heard ,or read that the water temp sender and adapter off the F OR 2F will screw into the chevy no need for adapter .,other thing is that i do not have the senders or a cruiser motor kicking around to get the senders from to make the adaptors( don't no thread pitch) .but i thought i would ask this question before i started hunting down the parts . also do the gauges read the chevy motor very acurately when using the toy stuff on a chev motor ? hope this makes sense . i would like to use the toyota gauge cluster because i just got ahold of a chrome plated dash . in the process of putting the truck back together
there is no need for the "adapter bushing" AA sells. it is the OEM toyota temp sender bushing that is in the head. you will need the sender and the adapter bushing from a 2F(not sure if early F motors are the same?). as for the oil pressure gauge, the toyota thread is 1/8" bspt 28 threads/inch and the chevy SB is 1/8" NPT 27 threads/inch. So they can thread together with a little effort, although I would hit home depot and get a 2" male/male 1/8" NPT tube and a female/female 90degree 1/8" NPT fitting to clear the intake manifold. screw the extension into the block pointing upwards, thread the 90degree fitting on so it points back, and install the oil pressure sender in the open port of the 90degree fitting. use a little sealant on the threads, and once installed, check the ohm value from the sender body to the block to make sure you have a good ground path.
the toyota gauges will read the engine fine. my v8 ran a touch hotter than the 2F and the oil pressure on my fresh v8 was also a bit higher than the 2F
On the coolant guage and sender, you should match the sender to the year of the guage. THe 72 and older like to run together; same for the 73 and newer.
The oil one is not as finicky.
I prefer a 45degree elbow on the oil tube to the 90. Better clearance over the manifold, and less likely to get banged against the firewall. I think that's the way AA does theirs too. :)
