stock color rim paint
I'd stand back....can of worms about to be explosively opened.
Rustoleum Pro Smoke Dark Machine Grey in a rattle can is what I used. My only reference is a faded wheel, so I can’t tell how close it is to original, but here are some pictures painted, against the cityracer grey wheels, and mounted.
I used aerosols but it comes in pints and quarts, just not sure how to get it flat/ without strokes.
I painted some stock rims for a friend who didn't want the gloss look of Rust-Oleum smoke gray. Ended up using this and they turned out great. The slight texture and flat look made those wheels look amazing on his 40.
This works as well. About a can a rim (both sides and middle width, 2 coats). This was for brand new OEM wheel that had black primer.
around 72/73 the rims were only painted gray on the outside... black inside and in the rim till the wagon style came out... pre 72/73 were gray all around... and earlyer rims were black till 68 model... and 25's were body color
in a nutshell:
Riveted Rims w/service hole
E-60 body color
Riveted Rims
61-67 black rims
68-72/73 gray rims
72/73 -8/74 gray outside only
Welded Rims
9/74-7/80 gray outside only
8/80-84 white wagon wheels
These are NA info
Market dependent … some European areas rims came white and you also had the chrome ones … too sporadic to pinpoint exact years … yet :)
Ive used this a few times.... Rustoleum Professional Dark Machine Gray.... I guess its a little more heavy duty than some of the others because it says "Professional"
