Steve's FJ 40 Project
I documented my first day with and getting to know my new acquisition. Thought I'd share:
I towed this rig from the CA desert to my home in the gold country and parked it under a tree appropriately for shade-tree mechanic work.
At least there was shade when I began today.
I removed the driver's seat for the first time and found a tool box full of stuff.
I also found an owner's manual, F engine manual and a chassis/body manual in the glove box.
My goal is to prep my rig for a replacement engine and transmission. Today I worked to remove enough stuff to get the transmission cover plate out and clear the floor for a cleaning and surface rust removal.
The seats are retrofit buckets that are quite comfortable. This photo shows how the passenger bucket seat was mounted.
Don't know what purpose this poorly bent piece of copper tubing is serving. Maybe someone knows and will chime in.
To be continued...
The rear heater radiator was full of antifreeze after sitting for a very long time. I hope both heater radiators and still functional.
Things were removed with no issues. I bagged and labeled fasteners and hardware. No surprises, just years of debris.
Here is a shot of the front floor board cleared and the transmission cover plate removed. I didn't shear off a single bolt today. I've got a desert vehicle with minimal rust.
I'm going to empty the back of parts, most of which I probably won't reuse, pressure wash and remove the interior surface rust. I still don't know what conversion will go in my FJ 40. My mind seems to change every few hours.
He are a couple shots of what I think is a pretty funky steering box mod. Maybe I'll get some comments and suggestions of how to correct it.
I had a fun first day with my FJ 40. I'm willing to continue this if other are interested. I'll have lots of questions.
HodTay
What a find!! Very clean-looking rig. Still has green antifreeze--good!
Those manuals are gold!
You absolutely need to post more pics of this-----
Where's' the drivetrain ??
I was gifted this 1971 FJ 40 from a deceased uncle. The three-speed is in the back along with everything else but the engine. I'm guessing the engine gave it up and the rig was to get a replacement engine. I'm speaking with a couple Land Cruiser conversion specialist to get ideas of what conversion to do. I want a dual-sport vehicle.
The purist in me is hurting, but, the enjoyment to keep it going and pleasure to the owner is happy. Nice rig..
This rig may still get a replacement 1F motor. I'm still on the fence about it. Georg has got a customer's running F1 that will become available very soon. Right now I'm just enjoying cleaning it up.
What is a "Dual sport" vehicle?--You can't get much better than the original FJ40 for a utility vehicle-it'll climb trees, walk over rocks, wade water and mud(ugh), ride the beach sand, and take you to the store for hardware, groceries, and hay if you have horses. You can also pull all your less fortunate friends out of a stuck situation when they need it--
If you want to go 80 MPH with no fuel consumption, then you have the wrong vehicle, regardless of the power train--it's a motorized brick
That's a really clean looking 40, I bought my rig with a big block, I wish I would have bought one with a 1f and then decided which way to go with it, but then again I've never driven a cruiser with a 1F so I wouldn't really know.
You've got one nice 71 there! I'm really glad you've got a rust free 40. I h8 rust!
I have an April 1971 FJ40, but it's not in near as nice of shape as your's. Mine apparently came originally from the Oregon coast, starting the rust. Then the PO to me brought it to the wet Willamette Valley. He eventually parked the 40 for about five years and threw a bunch of trash on the floor leaving it there to soak up rain water that came in through the rotted out drain tubes for the cowl vent. So I now have drain holes in the floor that allow the water to flow on through, along with the other rust. Fortunately the frame is very solid.
About that steering, I've never seen a saginaw installed like that. Mine had a manual saginaw from the PO, which wasn't the best looking install. But it was in the typical Saginaw swap location. You might consider changing to either a Scout II, or 60 series power box. Either one mounts to the outside of the frame, leaving the inside of the frame clear.
Don
This is the "not for sale" cruiser right? Looks really good. Love that color. You should try to keep all your posts in one thread so people don't have to go back and forth. Best to keep them all together, but then when you need to reach a broader audience on a specific subject (after searching of course), create a separate post.
