stereo problem
Atlanta, Ga
I put a new head unit and speakers in a few weeks ago and things have been working great. Today everything was working great until I stopped some place then came back out and no sound. The head unit turns on but zero sound and I had not played with any controls or anything. It worked one minute then twenty minutes later when I came back, there was no sound. Any suggestions as to what the issue could be here or how I could test for different problems?
Maybe a loose ground wire? Not sure how you hooked it. Your speaker wires could have shorted
Check your fuses, ground wire and power wire. Then move on from there.
If it turns on but no sound 'comes out', I would first disconnect your neg battery cable for a few minutes, then try again (resetting the head unit back to default settings). Some Alpines have internal amps that can be turned off, which would present the problems you are having (you didn't say what head unit you have, so I'm just throwing things out there).
Are you using the stock wiring with a wire harness adapter, or did you run new power leads and speaker wires? Let us know, that'll help with the troubleshooting.
Need specifics...
As mentioned before, the specifics of your install are critical for troubleshooting your problem. IMHO, if you have installed a aftermarket headunit and amplifier, the stock power/speaker wires should have been avoided at all costs. The majority of amplifiers manufactured today draw too much current for the stock wiring to handle. With this in mind, I would start by checking your fuses first. There may be a inline fuse located behind the head unit. Check this first.
Once again, I am starting with the basics. I would have many questions like; Does the head unit power up? etc...
Feel free to email me directly at teleguy11@yahoo.com to discuss further and set up a telephone link if needed.
Regards,
Shark
There is no substitute for just digging in and seeking out your problem. Obviously the head is either not putting out power or your have a connection lost or a connection short. Seek out the problem in order.
1) is the head putting out power to the speaker wires or the preamp outputs (whichever you used)
2) If it is, move on to the next step. Is everything hooked up still (look at every connection).
3) if it is, trace all wires looking for a short.
Many stereos have a reset button. If you have a flip down face it may be behind the face. It is just a little black recessed button. Try that. Also, some stereos have a high temperature turn off so if its been really hot it might have tripped the protection circut.
If you have the stereo installed in such a manner that that head unit is the only source of amplification to the speakers, meaning that you are not using any external amplifier(factory or other), and the unit powers up, there is basically only four possible reasons for no audio output:
1. Shorted speaker wire.
2. Shorted speaker voice coil
If any of the speakers or wires are shorted, it should trip the
thermal circuit in the head unit and shut down the amplifier
output.
3. Shorted Cell phone mute wire
If the head unit has a cell phone mute wire that is shorted,
this will cause the no output from the amplifier.
4. Bad amplifier in head unit
This is based on the info in your post and my assumpion of how you installed or had it installed. Any further info would be great. Feel free to PM me or post more info if you are still having problems.
I hope that some of this comes in handy in solving your problem.
tONy
