Stereo install!!!
Im getting ready to do this very thing...but I bought my installation kit and wiring harness from Wally World. (85-up Toyota) After getting it home, realized that this plastic was only for the 95-97 LC. Nothing about a 92. I called back and they said its the only one they offer for Toyota...so that needs to go back.
The wiring harness is a multi headed adapter...but I was doing some searching on ebay and found this:
Stereo Wire Harness Toyota Landcruiser 91 92 93 94 - eBay (item 110181774230 end time Feb-13-08 16:57:49 PST)
Specifically states "Amp Integration harnesses are needed when you are keeping your factory amplifier.". Connects to the RCA outs and directly into the OEM wiring in the vehicle. Anyone know if this is true or if the Schoshe connecter I got from Walmart will work?
Im just replacing speakers and head unit...not the amps.
Thanks!
Do you plan on using the factory amp or are you going to bypass it and use the amp in the HU (assuming it has one)?
What about speakers? Many of us put new speakers in the doors and disconnect all the rest, what is your plan on that?
Uh... I'm no electrical engineer.../quote]
You don't need to be one to know that using wire nuts is not just :hillbilly:, it is the wrong tool for the job. Crimp connectors or soldering are the only ways to go on automotive electronics. Unless of course you are in to car-b-que's
Come on, guys :rolleyes:. This works and stays put. Low tech is the way to go.
Its a 15w x4 HU. I am definitely replacing the door speakers. Only other ones in my '92 is the 6" woofer in the rear and the tweeters in the cargo roof. PepBoys has some really small Sony Xplode tweeters that I think might fit back there. The rear woofer is getting disconnected or a 6" 2, 3 or 4way will replace it.
That being said, i guess I am using the HU amp to feed the car amps...can I do that?
I did my own axle rebuild, but I dont have a clue what Im doing with replacing my stereo. :bang:
No, wire nuts do not stay put. With vibration they spin off. The only way to make them secure is to subsequently wrap them with electrical tape. Its easier to use crimp connectors and be more certain your rig wont burn down. DOnt use solder either. Have a look around the electrical on your rig. I have been all over mine and I have not yet found a soldered joint.
Karl
Just found this in an old thread...
Dunno how similar the LX is to the TLC but their are 2 or 3 different harness adapters that will fix you up. One plugs into the OEM wide plug that's is used with the OEM stereo, then you have two gray plugs back their as well. The gray plugs are probly easier to use as it has more appropriate wires BUT the other harness has RCA's for plugging into the headunit. (It's labeled as a amp integration harness by Metra, the one that uses the two gray plugs is Metra 70-1761
1) DO NOT FEED THE OEM AMP FROM YOUR NEW HU PERIOD.
2) YOU SHOULD DISCONECT THE OEM AMP AND DRIVE YOUR DOOR SPEAKERS DIRECTLY FROM YOUR HU OUTPUT.
3) THE REAR WOOFER HAS IT'S OWN MONO AMP MOUNTED CLOSE TO THE SUBWOOFER SPEAKER AND BOTH OF THEM SUCK.
Do a search on previous posts and you will find plenty information and tips about hooking the HU, bypassing the OEM amp and very nice concealed subwoofer enclosures to replace the OEM :grinpimp:
The purpose of a subwoofer enclosure is to isolate the sound waves emitted in the front of the woofer against the sound waves emitted on the back of the woofer (since they are 180 degrees out of phase, one cancel the other). Because the OEM subwoofer is mounted on a plate without any good isolation between the front and the rear, it's bass output is a shame and today I still can't believe how dumb was the Toyota R&D team in charge of the 80's sound system:censor:
Basically in layman terms regarding the subwoofer there are two types of enclosures: 1) all sealed also called acoustic suspension and 2) Ported which have a small opening, tuned to reinforce the subwoofer output.
Most of the ported enclosures requires less amp power to reach the same SPL (sound pressure level) but are a pain in the ass to design.
I opted for a ported enclosure on mine, which was custom made to fit the ALL the space inside the rear quarter were the stock subwoofer came, but I had to remove the rear pocket, keeping it's door fixed in the closed position. The subwoofer speaker was located in the same position as the OEM facing the stock grill and the ported hole face rear OEM slots in the quarter cover.
It have a 8" JBL subwoofer drived by a 120W RMS amp in mono hooked to my HU head unit sub output. Of course you can go for a bigger size speaker but it should be a narrow type.
The HU's own crossover front / rear output were set to a high/low cutoff frequency of 120 HZ so all my four door speakers are not forced to reproduce deep lows which draw a lot of watts from the HU, and all the bass under 120 hz is handled by the subwoofer amp/speaker combo which relieve a lot of load from the HU.
Rear OEM tweeters are hooked to the rear door speakers.
In dash front facing speakers were disconected, front doors are components with 6 1/2 midbass speakers on the OEM location and the tweeters were mounted in line and as close as possible to the door handlers.
Rear doors are 6 1/2 ultra flat coax speakers mounted over spacers to clear rear windows.
All four door speakers are drived only by the HU and as noted before only a mono amp (located inside the rear left quarter as high as possible) is driving the subwoofer.
This set up of four 6 1/2" door mounted speakers allowed me to have a nice midbass, front door high position mounted tweeters provide a nice focalized highs for the driver and passenger but unfortunately the rear door coaxial highs are lost when rear passengers are seated. OEM third row ceiling mounted rear tweeters are garbage but what more can I ask from them.
I saw many people spending a lot of money on rear big subwoofer enclosures which sound great but for me is a waste of cargo space.
haha, I'm in the same boat with you buddy. Together we will triumph :lol:
Now I know who I will call when I need to rebuild my axels :grinpimp:
I share my electronic knowledge with you and you help me with the mechanic hard stuff :D
Anyhow I guess that with the proper hardware, the service manual and a lot of cojones, anything can be fixed , Am I right ? :cool:
I suppose this place is what it is because we can all put in our opinions, but this is lame advice. We should really at least be open to learning how to do things the right way and adjust our knowledge accordingly.
Roll your eyes all you want, but using solid-core wire nuts in braided wire, automotive applications is a notch below ghetto-fab, and does actually pose a safety risk. Just because you haven't caught your rig on fire yet, doesn't mean it's good avice for others asking how to do it the right way.
Agree with you. I even like more to solder the joints and use a heat shrink than crimping, it's more protected from the water.
Didn't mean to be offensive. It might not be an overkill setup but I can't see how those tightened nuts would budge in any case. I will keep you posted about my "ghetto" rig going up in flames. :D
Ok, wow...info overload :eek:. I just to make my radio play...how do I find and how do I disconnect the amp...and if I do that, what good is the wiring harnass that I just spend $20 on??? If I cut the amp out, the harnass will be as useless as the amp, seeing that all the wires that Im connecting with the harnass run to the amp.
Am I looking at tearing into the entire dash to remove the amp and hand wiring all eight wires?
The best thing for you to do is a search. The pics will explain much better than we can tell you here.
Not trying to put you off.
The factory amp. (I believe this is true for your year model) is to the right of the glove compartment. Remove the GC and disconnect the two harness connectors from the amp.
There should be two unused connectors behind your OEM radio that are there (provided by the factory) to allow you to bypass the amp.
I don't know what harness' you have....but several will work. I used a Scosche TA021 when I did mine. I did not want to use the factory amp. and just went with the four door speakers.
Any of the harness' simply allow you to splice the harness from the back of your new head unit into the harness you bought...which will then plug into the factory connectors.
Spend a little time searching the subject and then let us know what areas you need help with. I know it sounds daunting, but its really not. Just look at the pics. and other write ups.
Thanks flintknapper to clarify my post, I am sorry but the idea was not to scare him because bypassing the amp is quite easy !!!!! That's why I sugested him to do a search because unplugging the OEM amp was well explained in other posts.
When wire nuts are used on braided wire, it tends to break the tiny strands, which then causes the nut to eventually fall off. A wire nut is meant to thread down onto solid wire. -This failure is so common that the NEC (National Electric Code) doesn't allow wire nuts to be used on installations that use stranded wire in residential, commercial and industrial applications unless one of the wires is solid.
No offense taken by your comments, and no offense meant by mine. Just sharing my $.02
15 years ago on our own building we paid a premium to the guys who did the electrical wiring to solder ALL the joints and never had any problems :D
From my yet-to-be-posted installation:
I ran speaker wires from my new Alpine amp to the factory harness using the plain old Toyota adapter (not shown) from Crutchfield.
-KK
Ok, this thread is now legit....pictures attached ;p whoops, my bad kurt, nice pics ;p
In all seriousness though, here is the pic of my aftermarket headunit harness and crutchfield harness all hooked up. Look good? I didnt connect the antennae...I'm 98% sure this is correct.
Now I need to know how to get into my dash. I cracked the FSM and no dice. Anyone have experience on a '94, or do all the models have the same access route?
Hope this all goes in smooth and the pics help someone else out down the line.
Brad
1:15am....stereo installed and working perfectly. Sometimes I really hate having a little ocd. Sleep like a normal human being, OR compulsively work on truck :idea:
You guys are a bunch of enablers, and I mean that in the worst possible way :flipoff2:
Have a great Tuesday everyone :grinpimp:
I did it! Thanks for all the info. Pics can be found on my photo site.
Thanks!
