Stereo install!!!
Rosamond Ca.
WOW I had no clue installing a new head unit in the 80 would be such a PITA! No generic install kits available, made this a bit trying. I finally got it installed though. I had to "massage" the factory plastic dash panel a bit. I also replaced the speakers in the dash and doors. That was actually the easiest part. I didn't get any expensive stereo stuff, just something better than 1991 stock stuff. I am just so amazed at how much work I had to put into installing the single DIN head unit.
:confused:PITA? It's all about removing the right screws and not being afraid to "massage" the panels indeed. The FAQ is available in here somewhere, no?
I didn't put much work into mine.... Ran eight sets of 12AWG speaker wire behind the stereo, down the center console, under the carpet to an amp under the driver's seat. Then split the main power cable for my subwoofer amp and ran a second cable to the speaker amp. Then removed the stock speaker amps, replaced all 4 door speakers, and ripped out the other 5 speakers that sucked.
Huh... I really did put a lot of work into mine.
My head unit install kit must have been the reason for my frustration. I didn't add any speakers, just replaced them. The factory amp bypass harness is a blessing for this I will admit. Don't get me wrong "massaging/trimming" things doesn't scare me one bit, I just want it all to look good.
I didn't even think about hitting up the FAQ on this, as I have done several stereo installs on different vehicles. I didn't think fitting the head unit would have been an issue for me. Oh well.....
With the strength of the FAQ here It appears that almost everything on the FJ80 is already covered. There is barely a reason to even post anything at all.
I went to Best Buy and got a Metra brand install kit. I looked at Crutchfield, and they showed no kits available for the FJ80
Hmmm, I was thinking of doing this myself.
Do you guys think these will work for me? I'm not super good at this kind of stuff, so I just want to make sure. Also, will I need any harnesses or anything to put the stock stereo back in the Jeep I'm pulling the Pioneer stereo from? Much thanks!
Harness:
Receiver Wire Harness For select Geo, Lexus, Scion, and Toyota models, 1987-up at Crutchfield.com
Din Pocket:
Toyota/Nissan Dash Pocket Fits select 1982-up models including Lexus Chassis size I at Crutchfield.com
Can't say about the Jeep as the harness might have been spliced and botched.
But having installed half a dozen afetrmarket stereos in the last few years including the one in my 80, I noticed that colors usually match between HU and rig harnesses and aren't rocket science. In fact, the space in the 80 makes it very easy compared to other cars I had to work on.
And this helps a lot:
4 cents apiece at Home Despot.
The pocket at Crutch.field is handy, but needed some tweaking in my case (I stuffed an old sock between the HU and the lower pocket:D). There's a separate metal chassis that you want to assemble the HU and the pocket in before you load it into your dash. Otherwise, that's a sweet piece of cheesecake.
BTW: where are you in West LA? I'd be happy to give you a hand.
Cool, I may take you up on that offer! I've never done a stereo before. I'm just off the 405, between westwood and century city
Mainly I just want to make sure I have the parts, etc before I get in there.
This is the stereo I'm putting in:
Pioneer DEH-P3900MP CD receiver with MP3/WMA/AAC playback at Crutchfield.com
I'm assuming the cruiser is an E Chassis? What metal chassis are you referring to that I need to assemble?
Brad
I ordered a 2nd single din adapter for my 94 to play with on my install of my Uniden 520 under my single din radio from Crutchfield. You use existing screws with the kit. It's all of $20 IIRC.
The chassis (in fact, two metal plates with lots of holes and screw wells) would normally already be in your Cruiser. Disassembling them, screwing the HU and the pocket together and putting the whole bundle back in before you plug the wires is the way to go but I'm sure others will chime in as my English is a bit dodgy and I don't know if I'm that clear.
I can help you next Sat if you're willing to travel on Santa Monica northeastbound until you hit boystown;) and meet your rig's twin brother.
:cheers:
The chassis (in fact, two metal plates with lots of holes and screw wells) would normally already be in your Cruiser. Disassembling them, screwing the HU and the pocket together and putting the whole bundle back in before you plug the wires is the way to go but I'm sure others will chime in as my English is a bit dodgy and I don't know if I'm that clear.I can help you next Sat if you're willing to travel on Santa Monica northeastbound until you hit boystown;) and meet your rig's twin brother.
:cheers:
You were perfect!
That is exactly how it is installed.
:cheers:
Ok, if the pocket and harness get here I'll hit you up. May be heading up to Big Bear for the day actually to make use of the snow...kinda playing it by ear. Thank you for the offer, I'll let you know
Brad
Uh... I'm no electrical engineer, but aren't those made to connect solid-core home wiring? I would think these would be a very bad thing for a vibrating automotive application with multi-strand wire. :doh:
Use a crimp sleeve with a good crimp plier, or solder and heat shrink.
Uh... I'm no electrical engineer.../quote]
You don't need to be one to know that using wire nuts is not just :hillbilly:, it is the wrong tool for the job. Crimp connectors or soldering are the only ways to go on automotive electronics. Unless of course you are in to car-b-que's
Got the Pioneer head unit out of the Jeep and put the stock one back in. Easy peezy, under 10 minutes.
Hope the installation of the Pioneer into the 80 goes this well!
Im getting ready to do this very thing...but I bought my installation kit and wiring harness from Wally World. (85-up Toyota) After getting it home, realized that this plastic was only for the 95-97 LC. Nothing about a 92. I called back and they said its the only one they offer for Toyota...so that needs to go back.
The wiring harness is a multi headed adapter...but I was doing some searching on ebay and found this:
Stereo Wire Harness Toyota Landcruiser 91 92 93 94 - eBay (item 110181774230 end time Feb-13-08 16:57:49 PST)
Specifically states "Amp Integration harnesses are needed when you are keeping your factory amplifier.". Connects to the RCA outs and directly into the OEM wiring in the vehicle. Anyone know if this is true or if the Schoshe connecter I got from Walmart will work?
Im just replacing speakers and head unit...not the amps.
Thanks!
