Steering
Cobram, Australia
Hi guys we have a one owner HJ47 and trying to set the steering, i have a Toyota workshop manual and all the rods are distance set centre of grease nipples but i cannot set the drag link which the measurement is 855 mm and i have run out of thread and no more adjustment any ideas Thank you.
Can you post pictures of the configuration/components involved?
Hi Byron I am not got at thi computor stuff but I have taken some pictures and wil get my p5 to do it for me tomorrow night, the drag link is the problem the whole steering has been replaced except the box with new components thank you for time and interest.
"i cannot set the drag link which the measurement is 855 mm and i have run out of thread and no more adjustment any ideas"
Based on the photos, I assume you are saying the ends are screwed all the way in and the length isn't what the manual calls for. The only thing I can think of is if the gearbox/pitman arm was in the right position when it was put together.
The drag link and relay rod tubes are close in length but not the same. Are you sure you have them in the correct positions?
Thanks Bryon I have lined the marks on the pitman arm with the line on the end of the steering box thread.Thanks cruisermatt I will check the lengths of the rods when I get home tomorrow and let you know.
Hi
Hi Cruisermatt, i have just measured the two rods and the one that is attached to the pitman arm (relay rod) is the shortest thank you.
