Steering wheel question
Metro Detroit, Michigan
I recently bought a 40 that had a grant steering wheel on it. I am changing it to an oem wheel and I'm running into a problem. See pics
I think the spline count is ok because they are engaging and I can see the wheel and the shaft move as a unit.
Do I have the wrong wheel for my model year (1972)? Am I missing a part that I am too ignorant to know about?
Any advice would be appreciated. I'm new to the forum and have enjoyed learning from so many contributors.
Thanks
Alan
Open the hood and let's see what you have for a steering box. Maybe you have a mini truck PS conversion and they didn't cut the shaft short enough? Let's see where it goes through the firewall too.
FWIW, I wanted to buy a real nice circa 66 or 67 Steering wheel with chrome horn trim for my 71 but wouldn't you freakin know it... they changed spline #'s somewhere in 68 or so. (Dates unverified) I found that out just before I was going to buy it.
you have the later wheel, you need the 7/69-9/72 version.
Believe earlier is 36 spline and the later 33. The later style matches later cruisers thru the 94 FZJ80. Maybe later but those had a aibag. would have to deal with horn button and turn signal but believe it will fit the splines.
since your steering isn't stock, there's a good chance the tube that holds the shaft (on the 'interior' end) has been modified as well.
In my 40 the stock wheel was hitting my legs with my seat setup, so I had to go with a Grant. The only way I could get mine to work, though, was by pulling the tube and shortening the tube about 1/2" or so, then adding a locking collar behind the grant wheel and adapter.
My point is that, in order to get an aftermarket wheel to work (and especially when the steering isn't stock to start with) the factory wheel may not fit depth wise appropriately.
If the spline count is right you may be able to pull the shaft, and shorten the shaft at the other end (all depends on how it's setup.... pressed, splined, bolted, etc).
You may also be able to retrofit some sort of 'rigging' like using a locking collar as a spacer between the tube and the wheel itself...
