Steering/wandering issue...need help
So Cal
Hey what's going on gents/ladies. Like the title states, I have been having steering :steer:and wandering issues for a bit now on my rig (along w/a few other things). I have a 94 fj80 with a whole mess of miles (349,XXX), which I don't mind one bit. Not sure what the issue is though. I recently replaced the TREs from cruiseroutfitters and used the Tools R Us toe alignment method and still have wandering issues. I constantly have to correct steering wheel while driving, especially in the freeways, which makes driving a bit intense. I have to admit, that while doing some research, I read about adjusting steering wheel play by tightening that one bolt on steering gear box. It did help some but still not where I think it should be. And now, the gearing box is leaking fluid :mad:. I know that the leaking began after tightening the bolt, so the wandering issue was prior to me doing that and persists still. Any one willing to chime in on a possible Dx would be very very helpful. I kind of wish there was someone nearby willing to drive my rig for a bit and give me their opinion.
Like always, thanks for any help/advice in advance.
have someone get in and move the wheel back and fourth (with the engine off) while you look at all the steering componenets. if something is loose or worn you can tell... if its that bad.
what tires are you running? certain tires like to follow the dips/lines/ruts more than others...bfg's are bad about it...
Is the truck lifted?
I have a slight highway wander myself but I attribute it to my 2.5 lift 33 tires and stock panhard bars.
Danthman114 - I have done that, and nothing seems worn out or damaged beyond normal wear. The only thing I noticed were the TREs a while back and is why I decided to replace those but still problem persisted.
As far as tires, I am running Toyo OC A/T LT285/75r16 and they have a good amount of tread left. No unusual wear to be honest with you, all seem to be wearing evenly.
Milkm4n - my rig is stock height, maybe 1/4" to 1/2" higher due to new shocks but I really doubt it gave me that much. BTW, shocks are maybe 3 months new, all four corners. They are KYB brand, which I actually like the handling so far.
inspect all the bushings on all the suspension components yet?
its not necessarily the tire wear. some tires just follow the road. how much air pressure do you usually run and does it do it on all roads? did you recently buy them?
danthman - the bushings look pretty good still, except the ones from all four shocks, they're all new. None look cracked or destroyed or anything. I will re-check while I lift front/rear and see if all is still good.
I hear you about the tires. My old ones were BFGoodrich so yeah, compared to those, these are nothing like that. I usually tell them where to go.
I run all four with 34psi, used to be 32psi but Im testing if psi is related to the issue. So far, no difference w/more psi, not sure running 30psi or < is good. And I purchased them from a guy about 1 yr ago, so they were used but are in very good condition.
I do mostly highway/street driving but also do a bit of dirt/gravel/etc and is noticeable in any conditio, moreover, in paved roads.
My truck was wandering more than Bill Clinton at a sorority house party, has been pretty much that way since I got it 8 months ago and I thought it was all in my head, since my perspective was coming from small and precise sportscars.
Yesterday went to Hardline Fabrication in SC, Stan there installed front caster correction bushings (for 2in lift). During that process with truck on a lift, I felt the wheels for play, and amazingly they where loose. He tightened the front bearing nut, and the truck now drives perfectly straight and true. I am truly AMAZED on the difference, even with 33" mud tires. The truck now doesn't leave the lane, wondering "hey, whats that over there on the other lane, lets go check.." like it used to.
By the way, I had the front knuckles done by a pro shop when I bought the truck, so not sure if they got looser over time or just not done correctly to begin with.
If it's wandering around the road and the tires pressures are equal, it is typically caused by:
1) Wheel Bearings too loose
2) Worn/loose trunnion bearings or steering arm
3) Toe-Out
4) Too little caster (need caster correction)
The first thing I would do is check the wheel bearings adjustment, the trunnion bearings and steering arms. If those are in good shape, I would spend the $100 to take it to an alignment shop to have the toe-in correctly adjusted. If they use the 4-wheel computer setup, they will get it set properly. The larger and wider tires are MUCH more sensitive to toe adjustment and camber than one might think.
Then there's the issue of the road itself. Find a NEW road that doesn't have the worn truck-tire lanes that the wide tires are constantly grabbing and climbing up, thus "wandering".
Good Luck!
Izzyandsue & BILT4ME, both of you mentioned the wheel bearings, so I might give that a check when I get home tonight. Also, I did go to two different "alignment shops" and the wandering was still there. After doing Tools R Us toe-in method, it drove much better but it still wanders around. Keep in mind, this is a regular road, no worn-truck-lane or anything. It just sucks, especially when my GF drives it around and complains of how terrible the drive is due to steering. She would rather me get rid of it than spend money & time on it. I say that's out of the question but when my little girl is in there, it does make me second guess my decision about keeping it cause afterall, she they're my priority and safety is always on my mind with them on board.
The tape measure thing suggested by Tool R Us works, but it's only partially accurate. I used his method to get it close enough to drive it to the alignment shop. I like my truck to steer where I want it, but I'm also used to a solid axle 4wd and 33" tires and how they wander. If anything, they should be slightly toed-in a bit too much to make them steer better. But, the wheel bearings MUST be adjusted properly for ANY of this to be set correctly.
I adjusted my toe to the factory specs using aluminum angle clamped onto the brake rotors, etc. Once I was done, it wandered pretty bad.
I read that Tools or someone said a bit more toe is much better, so I loosened the clamps, marked the pipe and gave it another turn. Night and day. Not saying that's your problem, but these things are so simple to adjust, and you can't hurt much except maybe more tire wear (mine wear very well still). I rotate every 3000 miles with the spare in the mix which makes a huge difference.
"Tramlining" or "Tramming" is an old industry term where the tires will follow older and sometimes imperceptible "ruts" on blacktop or concrete roads. It will happen no matter what you are driving. If you are in good flat roads, then it is in the truck's running gear. The easier stuff first and work your way into the more expensive stuff. Wheel bearings nut torque can be done at home if you have the big ass socket. The torque is not high either.
Hey BILT4ME & Izzyandsue I did double check the bearings per earlier recommendations and they are w/in specs but prior to checking them, I did what a fellow member said..."raise front end and do the 12-6 giggle and 3-9 giggle to check for bearing and truinion play", respectively. I read that in a FAQ thread. I did giggle test and bearing check and all w/in specs.
Hey blkprj80, you mentioned to do more toe but is that more toe in or out? When I did the alignment, I had a slight toe in, I think of I had about 1/8th difference in measurements.
If you have 300K plus miles, you may have a pretty worn steering box.. my 80 series was wandering like you describe, and after I checked the easy things as BILT4ME suggested, I finally sent my box in to West Texas Offroad and had them do a rebuild and put in the heavier 105 series sector shaft (got it from CDan, Beno could probably get it as well). When it came back, the wander was almost completely gone. I had already replaced the TRE's, put in Budbuilt Tie Rod/Drag links, etc, and they all contributed a little to driving perfection, but the box definitely was loose and the rebuild cured that. HTH
Irowe_csp - the gear box rebuild is something that I am NOT looking forward to fix. You, as well as many others that replied to my original question have narrowed down my dilemma. Obviously gearbox would be the more expensive route. Very hesitant to work on that cause it seems difficult and could lead to more costly repairs.
I will do a do-over check on bearings, alignment & TREs. Gearbox rebuild is next after above.
Hey blkprj80 thanks, I did notice that your input on setting toe was added to FAQs, right on!!! I actually was using your numbers you wrote on that thread, so credit goes to you for that. I will give the alignment thing another shot and if all else fails, gearbox rebuild is in my near future. :mad::mad::mad::mad:
May I ask - how much did the rebuild cost? I just took delivery of my 96 LX450 and its got a ton of play in the wheel which absolutely drives me nuts about it, especially after my daily driver has no play whatsoever. thanks.
