steering stabilizer installation
Sacramento, CA
HELP! cant seem to get the stock steering stabilizer out, just will not budge. help me please
Use a small propane torch to get the rod hot (but not the not the stabilizer pin/bolt.) This will expand the connecting rod hole away from the stabilizer pin/bolt. Once you get that hot, whack the hell out of the rod tab where the pin/bolt goes through with a BFH. Usually after a couple whacks it will pop right out. To keep the rubber grease boot (and the truck) from catching fire, I tear mine away with pliers and wash the grease away with brake cleaner first.
thanks alot, need to leave in a couple of hours and hammering it straight up was not working
Here is my previous post on this subject. There are lots of ways to remove the stabilizer.
I battled removing my steering stabilizer (pickle fork was wrong size and my gear puller kept slipping off). So I went with Plan C.
1) Used right angle grinder with cutoff wheel and cut the damper at the mounting pin.
2) Used a vice to press the pin out. It popped right out. Be aware that when the pin pops out the vice will fall, so plan accordingly.
You require a sledge hammer and not your average carpenters tool.
2-5 lbs will knock this beast off in seconds.
Seems like a C-clamp would be a little less un-wieldy than a 20# bench vise. :D
-B-
I pickle forked it out- but the vise method seems to be the best idea yet. I don't know if a C-clamp would generate enough force to get the thing off. I used a vise to remove the plate from the old stabilizer on the passenger side of the car- the little triangular plate- since I couldn't get the stabilizer off with the plate attached to the cruiser. Lost a bit of skin in the process as well...
