Not sure if the OEM bushing is even available anywhere, but the way it disintegrated, I thought I would give it a go to see if I could come up with something that worked better. I'm fairly addicted to using old crap in my garage for this kind of thing. Here is my solution to a loose steering shaft with no bushing whatsoever—recycled OME polyurethane shock bushing.
It took some time on a grinding wheel in the bench grinder to get the OD correct. OD for this part is about 35mm, by the way. The ID was a little trickier. I started with a 3/4" step drill bit. It worked, but wasn't big enough. The shaft is 20mm wide, so I was going for around 21mm for the ID on the bushing. I used a dremel sanding bit in my drill and just kept trying it. I actually needed it to be a bit bigger than 21mm to let the shaft move freely inside the bushing.
Final fitting is just about perfect. I put a little bit of SuperLube on the bushing to lube it up a bit. The shaft now spins freely, but doesn't wobble around. All in for $0 and about 30 minutes of back and forth.
