All right, I've been on this suspension and wanted to upgrade my heims. This got me going on my steering, as my heims would make a good unit there. I got some free 1.5" solid aluminum hex I can make some new tie rods with.
I have had the "death wobble" I added that to bad alignment. I am using the cruiser power steering, with the push-pull box in the fender. That little bearing case that is mounted in the front d.s. frame rail and crossmember, has the 2nd pitman arm, is broken. My spring hits that tie rod end, under heavy articulation, and broke or bent that unit. I think a heim there would give me close to an inch of clearance, but a whole new steering system would be better. I'm looking for a new "bearing case" locally, hopefully super cheap, just as a bandaid for now.
I don't know I really dont want a scout box, or some kind of a mopar unit. No on a full hydro system, I don't like that idea, if my engine dies, no steering! Hydro assist would be cool but not the priority right now. So I'm thinking either a Chev saginaw box, or a better Toyota unit. An ifs would be cool, heard an fj60 unit would be good. I might be very interested in an fj60 box, not familiar with it. I have allways been torn on this decision, that is why it's never been done. Any suggestions?
I am running the front fj40 springs, my hanger is the stock, mounted flush at the end of the frame. I want a box that will be in the best position to avoid this problem. Also quickest and cleanest to install. I could change the suspension a bit, but it is just right as is. Well..... other than this problem hitting the tie rod end on the pitman arm. I am gonna' do some new steering arms, mounting the tie rod behind the axle, above the springs. Just want the best setup to fix my problem, hate the "death wobble". I need a solid steering, with no slop in the wheel, or wander.
