Steering play, I'm stumped
Sacramento Ca
Couple months ago, did the slee 6" kit, steering link upgrades, and 37's. "LaFawnduh" got some high heels for her big ol butt, and now when offroad, in low range, theres a problem. Noticed it a few times now when in 4low (yes, part time kit is awesome) when on relatively flat ground, climbing a rock with the LF tire, said tire turns a bit while climbing, and steering wheel does not. I looked over everything I could think of that was recently done, including tie rod ends, drag link ends, wheel bearing preload (which was a bit loose so we tightened that up, didn't help the situation). Then I went to things like splines if pitman arm, rag joint, and all splines on the steering shaft, even made sure the wheel was tight. Still getting that play and its concerning me. I don't want the Mrs and daughter to have any mishaps if they take LaFawnduh out for a spin. The play is minimal in 2wd on the street, it seems like what one would consider normal or close to it with a SFA and 37's. Anyone ever had this problem? Also, I checked the knuckles and trunion bearings as well, since the axle had a full teardown, and all new seals when the lift went on a couple months ago. I'm stumped, and if I hadn't experienced it a few times now when offroad I'd never thought twice about it. Oh yeah, FTR, I did check the steering box itself, including mount/frame, not cracked, and bolts are as tight as can be. Help!!!!!!!!
Shortly after I finished the suspension I also did the part-time 4x4 kit with manual hubs. For a while I drove with the hubs unlocked. Then one day I drove with them locked but 4x4 disengaged. That made a huge difference in on-road handing. That's when I realized most of the body roll was attributed to my twitchy steering - the "dead spot" common on y-link / inverted T setups (unrelated to Brian's kit however). So locking the hubs helped tighten up the steering a bit which really improved the truck's handing.
Wonder if it has something to do with the part time kit. Jose had this to say about his part time kit. Seems his steering was improved by locking the hubs but driving 4x4 disengaged (on-road). May not point well to your issue since it's in 4Lo though, but similar upgrades with similar symptoms.
If nothing is loose, it's likely the slow motion version of bump steer. When you compress the tire, the drag link has less angle and thus effectively elongates, steering your wheels. This is one of the problems with very high lifts, is that the drag link is steeply angled, making you much more susceptible to "bump steer".
Makes some sense, but with locking the hubs, isn't that going to turn your axles, ring gear and driveshaft, still giving you "most" of the wear you're trying to avoid with the kit? @jcardona1 whats your take on this? You drive with them engaged all the time on the street now?
Except the track bar makes the axle follow the same arc
This makes sense as well, and I'll have to look into it more, taking this into account. I just find it weird it only happens on the left front tire, in low range, and in 2wd, around town/freeway its not really noticeable. There's a little bit of play, but nothing a 20yo vehicle wouldn't seem as excessive.
SNIP
OK, that's a good place to start...
Have you ever adjusted the centered nut and slotted shaft that adjusts the play in the steer box itself?
If not, in an older truck, I'll bet you find unneeded slack there that might help. The bump steer theory is a good one. But you may gain on it a little if the steer box adjustment was tightened, but...
Before doing anything, research the process. Too tight is bad, bad, bad. So a little at a time, check and recheck so you don't overdo it if you decide to adjust. Threads here will help.
I recommend you do not adjust your steering box. That is not causing your problem and the adjustment is critical to prevent binding of the sector shaft on center. Unless you are familiar with how to adjust the sector shaft preload, you are more likely to cause harm, than improve anything.
Regarding the pan hard bar, it does not prevent bump steer. It's the relationship between the drag link and the tie rod that matters (they should be parallel). The pan hard may limit axle side to side movement somewhat, but does not cure bump steer. That would be way too easy. With 6 inches of lift, you have a very steep drag link angle, which if EVERYTHING else is tight, is likely the cause of your problems. I'm assuming you have looked for and fixed any bearing play, worn bushings (in leading arms or panhard) or knuckle looseness.
You may not have a problem at all. What happens with rapid steering inputs on the road?
Steers normally if rapid movement. Has a bit more play than I like if tracking straight and barely cycling the wheel side to side. I'm very familiar with bump steer from my old rig, and its pretty close to the same with this rig. Our California potholes are getting bigger everyday, and it sucks. I'm not going to dive into the (steering) box, I adjusted one long ago with horrible results. Yes, all the bearings are tight, all links in steering and suspension are new, and I've checked them all. It almost feels like (if you've ever encountered this) a castle nut backed off and the tie rod end is half out, slapping back and forth. Weird description, but in low range, that's what it feels like. Have had two highly skilled, competent friends crawl under it to try and see anything, no such luck. :bang:
