Steering knuckle grease question.
I was under my truck yesterday, and was going to add a bit of grease to the knuckles. I read here 3/4 full of grease is perfect. My question is how do you determine how much is 3/4 full?! I don't want to overfill and have grease oozing out of the wipers and blowing seals out. TIA.
The coating on the swivel is normally a good indication, or stick a zip tie in the filler plug hole and use like a dipstick.
Regards
Dave
I will take a look asap. the grease gun I bought s*** the bed after the first 10 pumps :( I live in a spot where parts stores are closed on Sundays , so it will wait until tomorrow. Maybe i should have bought the grease gun breakfast:flipoff2:
@NLXTACY I feel like i will be rebuilding the front axle. I smelled gear oil in the hole where the grease goes. Do you sell a seal kit?
No seal kits
Sometimes i find that i pump a lil grease in then drive around a bit to get a settled reading helps for accuracy. I also recommend a metal "zip tie" ---:cigar:
No need for a grease gun. I prefer my patented "ziplock freezer bag" method. Take a ziplock freezer bag, turn it inside out, put it over your hand like a mitten, scoop all of the moly grease out of your tube or tub, hold the grease and pull your hand out and it turns the ziploc right side out, cut a small hole (about a 1/4") in one corner, squeeze the grease in to that corner and twist the ziploc tight like a pastry frosting bag, squeeze and fill your knuckles to 3/4 full. I use a piece of 8ga wire to push it around in the knuckle. Drive it around then check the level.
I bought the Trail Gear inner seal and the wiper seal kit @ Ebay, beefier than factory, so far working great, and Royal Purple gear oil...
Trail-Gear Trail Safe Toyota FJ80 Knuckle Ball Wiper Seals *PAIR* Lexus LX 450 | eBay
Trail Gear Trail Safe™ 90-97 Toyota FJ80 Inner Axle Seals *PAIR* Lexus 450 95-97 | eBay
@cruiseroutfit cruiseroutfitters.com for rebuild kit.
If your grease gun "shat the bed", it probably has an air bubble in it. You may need to pump it like 70 times to pump out the buble. Pull the handle out the back and lock it into the plunger and push on it while pumping to assist in pushing out the bubble.
If it smells like gear oil, you need new seals.
If you are not going to rebuild it soon, put in grease anyway. I used Valvoline Palladium with Moly in mine. Sometimes special order at O'Reilly or NAPA depending on location.
Gear oil is the cheap 85W90 version. Check it to make sure it is clear and full.
Always loosen the FILL plug before removing the drain plug.
Interesting how people come up with different ideas to complete a simple task. I have found that the grease gun attachment diameter for the zirk is the same width as the fill hole. Whenever I am under there I put a half dozen pumps in there, just to keep it topped up.
Regards
Dave
Regards
Dave
I seem to always need more than a half dozen pumps... :hillbilly:
Think they make drugs for that now?
Most of the time add 1/4-1/2 tube per side.
Regards
Dave
I guess you're "under there" often. Lat I did it I did 70 pumps of the grease gun handle on each side to get to 3/4 full.
Over the last year and a half,I guess I go over the 80 roughly once every 3 - 4 weeks? I 'get out' a lot more now at most weekends for 2 or 3 days, and give everyyhing greaseable a few pumps, (propshafts, knuckles, drag link, tie bar etc), just to make sure all is good.
Regards
Dave
