Hi all, I'm having issues with my 80 wandering around the road. I've rebuilt swivel hubs, new wheel bearings, new tie rod ends, new caster bushes... It feels as if it's not retuning to centre correctly (has tough dog RTC damper) the steering wheel will get close to centre but not straighten out 100% therefore I have to compensate the rest, I have to consistently go left to right to get it to track correctly.
And it does it from both left and right corners, it's extremely annoying!
Any one else had an issue like this or able to direct me in the right direction?
I may be speaking out of ignorance, but many Mudders have had to replace the output shaft (can't remember the tech name for the shaft) in the PS gear box. The splines get twisted where the pitman arm attaches from hard wheeling. It causes alignment and steering problems. There are numerous thread on here about it, with pictures.
How many kilometers on your truck (since you're in Australia)?
Not familiar with the Tough Dog, but assume RTC = return to center? If it helps with that, could be an issue with it, so disconnecting will help sort out whether it or the steering itself is at issue. I suspect you wouldn't want to leave it hooked up when troubleshooting the steering in general, as it may affect the results you find.
A general inspection of the steering gear for obvious issues, looseness, etc is a good place to start.
If you have a high mileage vehicle under tough conditions -- both a rather more distinct possibility in Australia than some other places -- and everything else checks out, the wandering near center could be steering box wear. Don't do anything with it until you've both tracked down and ruled out other causes AND have familiarized yourself with the correct procedure for adjusting, but there is a screw on top the steer box that is a way to take the excess play out. Problem is, it doesn't take much to overdo things and mess stuff up worse, so don't jump on it as low hanging fruit, only if analysis points to it.
Another factor that's more obvious to check is the frame around where the steer box mounts. It can end up cracking and letting things flex when they shouldn't. That a major repair, but can usually be diagnosed without too much trouble, because cracks will be visible radiating from the mounting points.
how much free play is the the steering wheel going from left to right, maybe adjusting the preload in the steering box. I had a lot of play before I changed out the steering box, it was leaking not because of the play, and the free play was cut down significantly.
I replaced my damper with an OME thinking that was it, the old one was due for replacement but the issue still persisted, any uneven or patched asphalt and it would have a mind of it's own.
I had mismatched front and rear tires but swapped them since the rear had a bit more tread, it felt better but after I put new boots on and set the toe as wrote up here on mud it felt right as rain. this was all AFTER I did a complete front axle overhaul too so I feel your pain!
I'd say you swap the two tires with the most tread to the front and take it for a spin and see how it feels for a no cost assessment!
Caster and toe are critical for proper return to center. The whole point of caster is for this effect. Toe matters to make sure there IS a definite center. Make sure you are properly aligned first.
Second, the steering damper should have a neutral zone to allow for tolerances in the tie rods and rod ends. There are a lot of tolerances which when added up should be less than the neutral zone of the damper. Usually it isnt the damper's fault. I assume you are running larger tires and a lift which would result in need for a higher damping force, but length should remain the same.
I had this problem, found some minor wheel (side to side) play when lifted front wheels of the ground, it was the shaft nuts needed to be tightened (needed adjustment after prior birf job), now runs perfectly straight.
Mine wanders almost like a bumper car ... (kidding) ha , and the steering wheel goes back and forth several inches... figured it was just worn. it goes where I point it so thats fine , its just a lil sloppy , so maybe I can tighten whatever on the steering box and maybe that'll help.
