Steering issue (Saginaw) -
Austin, TX
I’ve got a 4-bolt Saginaw at crossmember with Georg’s plates and a “canned ham” pump on my ‘76 FJ40. PS works fine on-road in 2WD, but randomly looses assist off-road in 4WD. Fluid is full and sometimes there is a noticeable squeal and sometimes not when it happens. Happens more often when locked (has ARB), so seems to be related to force needed to turn wheels. Thinking it’s the box but wanted to get input, belt is appropriately adjusted and PS pump squeal not consistent with issue. Should I just replace the box or is there a way to be sure? Box turns lock to lock with assist in 2WD and w/o assist on jack stands with no binding.
Tucker
Sounds to me like you don't have enough belt wrap around the power steering pump pulley, belt should wrap at least 50% of pulley. When you are off road (particularly in rocks) every time your tire comes up against a rock it wants to turn aside from the rock, and since your grip on the steering wheel wants the rig to go straight, you then try to stall the pump. Sooooo with not enough belt wrap on the pump pulley, it squeaks all day long in rocky terrain- - - make sense ???
Pics of belt wrap would be helpful. Is the high pressure fitting on the box kinked? I've seen the bend kinked slightly on diy installs.
You might just need a bit more pressure from the pump. There is a mod to the output check valve(?) that increases pressure. It might be in the tech links.
Found it:
There are a couple of mods you can do to your pump. One to increase the flow, and one will increase the pressure. I drilled an orifice out to increase the flow. Easy mod, and it made a significant difference for me. Just don't over do it. Just google the mod for instructions.
Yes thats the one
Normally you would want your P.S. belt to go from crank pulley to P.S. pulley only (i.e. 50% wrap). If GM had the P.S. belt also include alternator (3 pulley belt wrap) they might have gotten away with it since most those vehicles would not have gone out into a boulder patch with 35's ???
