Steering Column
Little Rock, Arkansas
Why would a cruiser head tell me that a 72 column is junk, and that a older shaft would be better. I have a 72 that has the shifter already relocated to the floor. The only thing that I can think of is that the older ones have the key on the column giving you the ability to lock the steering wheel. Are there any other major differences betwwen columns?
Jake
the "newer" ones have the key on the column. iirc 72 or 73 was the change over.
older ones have the key on the dash, to the left of the column.
actaully no US spec 40's have a locking steering colume, you can add it however, use fj60 bits and I hear they fit right in(to a late model 40 at least) Same with the late model "pocket" use a fj62 lock......
some non US 40s have the locking wheel as stock.
JOhn
I think that is what is called "harpoon steering" so if in a accident the column will go thru you chest like a harpoon.....
not sure what year it changed.
ozarkcruiser said:
So nobody has anything bad to say about the 72 column?
Jake
true.
do you know how hard of a hit that would have to be? and that "if" you got hit(or did the hitting) that hard in a 40, i really believe that you would have more problems than "just" the column getting you.
by NO means 'am i saying it could not OR did not ever happen, just thinking out loud.
There was a U Joint added between the steering column and the steering box in 9/72 (which would be 73 model year). The key went onto the column from the dashboad later yet. I am pretty sure that 72s and earlier were all essentially the same (although the steering boxes changed a bit in 68, and again in 69).
you took the words right outta my mouth! I would def add one of those. I have a question tho. How are you fitting it onto your column? thanx, Rachel
what specifications do you need to fit a collapsible shaft to the column on your year?
