STEERING BOX RELOCATED
Ok, here are the things I see that I would fix:
(1) Doubt anything is wrong with the steering gear, other than it is manual instead of power. Saginaw manual steering is better than stock manual steering because Saginaw conversions get rid of 2-3 middle men (less hardware between steering wheel and tire).
(2) Steering gear did not interfere with front bumper, PO just preferred a custom front bumper.
(3) I doubt sheering shaft rubbing against front motor mount cushion is a problem (or causing shake/wobble). Culprit may be (a) steering stabilizer shock shot many years ago, (b) poor alignment, (c) need to run higher pressure in front tires, or (d) all of the above.
(4) Your steering drive shaft is very old school, and has no built-in slip yoke (so you are destroying the bushing under the steering wheel, or back side of the wheel). A new steering drive shaft with built-in slip yoke at the bottom u-joint will also improve the drive shaft angle so that it may not rub the motor mount (or at least not as much).
(5) Your rig has Coil-Over shocks, absolute poo-poo, they work about 90 percent in the wrong direction, your rig becomes "double spring loaded", with violent rebounds.
Contact me about info on an improved steering drive shaft and a freebie Saginaw Steering Conversion Instruction Manual!!!!
Hey Jim - a truck I recently purchased has what I believe to be one of your saginaw manual steering conversions. At first I thought it was some jerry rigged setup but research led me to one of your kits. It's only jerry rigged on mine from PO installer hack job.
I'd actually like to redo it as it should be for the nostalgia, so any instructions or pics would be great! jonbmabe@gmail.com
Cheers!
Jon
By the way, if done correctly, there is nothing "back woods" about a steering conversion. Mine looked similar to yours when I bought it (albeit, power steering, not manual). I had it re-done correctly and now it looks much more like it belongs there:
Before:
Poorly welded-in scab plates and a poorly cut hole through the frame. Mounted to a solid rod, and connected through the frame with a spud shaft what would cause the rear of the box to leak. In addition, the box was literally WELDED to the plates (no bolts). You want to talk back woods? Let's try welding cast iron to steel!
After:
Removed the bad double-plated, welded mess. Repaired all the burn-through on the frame horn, patched the front cross member, cut a new hole, and sleeved it properly with DOM tubing. I honestly think it looks like it belongs there:
The only thing I would do differently, if I did it again, would be to space out the box from the frame horn just a LITTLE further, as right now it interferes with my front shackle, which I had to "modify" to make clear.
It might actually be easier, with all the holes already drilled, to keep the manual saginaw box and just clean up the set-up, rather than go back to stock. There is nothing wrong with either set up, just up to personal preference.
Back before I had my first digital camera I had a couple of doozies roll in. Both would have had places on the Wall of Shame.
One had carriage bolts and wingnuts holding the box to the frame. The other had a receiver tube welded from the front crossmember to the bumper and up against the box to try and keep it from flexing away from the mounting plate.:eek::eek::eek:
Well as I dive more and more into thie 75 FJ i keep finding out interesting things. Yesterday I found that the steering box, a saginaw, that is placed out off the frame really shouldn't be there at all. Sigh....apparently the original owner wanted "headers". Soooo...what to do, what to do..? Owe I know, I'll get rid of the original steering box and equipment, move the aftermarket Saginaw box out to the front frame near bumpers, opps front bumper in the way, I'll cut that s*** outta that and make a "new bumper"... opps got more metal in the way underneath , no problem I'll cut that s*** outtta that as well..gotta have my headers...
So now what...? I took some pics of the areas in question.. maybe by looking at it you guys/gals can let me know what is savagable... I am going to take the headers out and put it back the way it was...
Thanks again... just need some advice..
View attachment 896645 View attachment 896646 View attachment 896647 View attachment 896648 View attachment 896649
If you’re going to stay Saginaw and go power, you will have to cut the mount off the frame, because it is too far rearward to accommodate the additional bulk of the power box.
At that point you’d be a lot better off getting a better mounting plate, like the one I or Georg or Luke sell. The ductile steel plate you have compromises the ability to use stout hardware, and there are horror stories,complete with pics, of those plates failing.
