Steering Box Mounting
SE Mo
Went thru the search looking at all the info I could reguarding Scout/ FJ60 p/s installs, and came across some pictures of Mark W's setup. On it he welded a heavy plate on the outside of the frame, then bolted thru it and the OUTSIDE frame member. To me it looked a whole lot easier doing it that way, as opposed to plating the inside frame rail, and sleeving. I know Mark is HIGHLY reguarded in the Cruiser world, and I'm NOT questioning his method. Only asking if this would be an exceptable method on a 75% DD, or would it stress the frame rail by putting all the pressure/work on the one side. I'm at the point where I'm ready to mount the box so thats why I ask. It looks to me that would also keep you from having to move the radiator over to the pass side to clear the steering box. Any comments on this? Thanks, Al
When I did mine I used the plate as an easy way to space the box off the frame rail to clear the radiator. The down side is the more you clear the radiator, the more you can interfere with the shock tower. If you use 3/4" thick metal it should clear your radiator support, but may require trimming on the fender support. PM me with a e-mail address and I can send some pictures that may help clarify this.
As far as strength goes are the factory 60 PS box bolts sleeved through the frame, or are they bolted to the outside with captive nuts?
The original reason that I looked at using the plate was to provide clearance from the radiator bracket.
It's important to use a plate that is large enough to span from the bottom to the top of the frame. That way when yiou weld it on you have the structeral integrity of the top and bottm faces of the frame rail, not just the outer face.
I have done at least half a dozen FJ60 conversions this way and three Scout boxes using the same approach.
No problems. Plenty strong. It won't fail.
Use 3/4 inch stock. Any more will accentuate clearance problems with the shock tower. Any less will not provide enough clearance from the radiator bracket.
Hey Al
It is getting to warm to still be messin around with the cruiser. Hope you are done by spring. Good luck. Bill
Thanks Guys. Bret you have a PM. Yea Bill, I hear you. Kind'a like 2 steps forward, 1 step back at times. Looking at building the mount for the p/s pump right now since I'm at an impasse right now. Al
Here is how we mounted the FJ60 box on my frame:
https://forum.ih8mud.com/showpost.php?p=1008722&postcount=20
Getting to the inside of the frame rail up there is a real b$tch...
The fabricator that did this was confident we would have NO problems with this box mounting (insert off-color joke here)
