Steel Spoke Type Wheels
David70FJ40
Older Than Most
High Point, NC
If this is old information please excuse me and just ignore the info.
I have been looking for some of the older style steel spoke wheels, I believe they are now called wagon wheels, none that I found would fit. Something was always wrong. The first set had a 4" offset which would require a spacer which I was reluctant to use.
Last week I stumbled on a listing on eBay that proved to be fruitful. The brand Pro Comp has a 15 x 8 wheel, "D" style openings, model 51-5883S3.5 that fits. The lug pattern is 6 lugs on 5.5", the center opening is 4 1/4" and the offset is 3.5" which clears the tie rod ends. The rep at 4WheelParts.com I spoke with stated they WOULD NOT fit so I took a chance and emailed Pro Comp and had an exchange with an experienced rep there. From all the measurements he gave me I was hoping for a fit so I took a chance and ordered 5. I opened the first one and tried it and it was perfect.
SO, if you are looking for a spoke type wheel, try Pro Comp.
DISCLAIMER - I am in no way associated with Pro Comp wheels and am not acting as an agent or spokesman.
Hope these photos help.
What year is your rig? Looks like you have front disk brakes. Do you have stock calipers? Prior posters found the back of the D windows did not clear the caliper.
1970 FJ40, aftermarket disc setup from JTOutfitters using GM calipers. I bolted the wheels with two lugs and was able to rotate easily with no apparent interference. The edge of the caliper to the rim has good clearance and I was mainly concerned with clearance between the rim and tie rod end.
