Starting issues
Saratoga Lake, NY
Just recently I have turned the key in the ignition and the truck didn't do anything.
I can see the gages move and the lights dimm on the dash so power is going to some point.
I wait a minute, sweat and turn the key again a couple more times and finally... contact.
My starter brushes are in good shape, would it be something to do with the ignition?
I haven't changed the fuseable link yet.
Anyone have these issues? I'm at 190k miles? What else should I look for?
Multimeter and measure some voltages when trying to crank. Voltage at battery, voltage at harness side of fusible links. Voltage at starter motor and solenoid. Obviously a 2nd person to crank while you probe voltages would be helpful...
cheers,
george.
Another member told me, on high mileage trucks that it's common to have the ignition switch fail. He described the same problems your talking about, he replaced his switch, no more problem.
Ok, thats what I need... A second person.
cheers,
george.
Thanks George.
Think I'll just order the switch with almost 200k miles on it that has to be the problem. Hope the install isn't too painful.
I just got the truck back from Landtanks shop in Massachusetts. I wanted to get the front axle repacked and a tune up.
He completely went through the running gear, cooling system, and steering system. Too ba I didn't add this to the list. """"""""
The truck runs great and I'm good for another 100k miles. (God willen and the creek don't rise.)
So I cleaned the battery cables and haven't had any problems starting the truck. So the score is Landtank 1 and me ......
So far.
