Starting issues
Iowa City IA area
So my 96 is having starting issues. When you turn the key to start it just clicks. If you turn it between off and start several times real fast it will eventually catch and start. Do you think it is a loose wire between the battery and starter or the starter seloinod and what is the best way to get at the starter? Through the drivers side tire?
That clicking is cause by a weak battery or something in the starter system not maintaining a solid connection. Loose or corroded battery cables or post, loose cable or wire connnection at the starter, starter solenoid contacts burnt and/or worn, worn ignition/starter switch. Start with the easiest and work toward the hardest item to troubleshoot. My bet would be either the battery weak, cables corroded or loose, or the starter solenoid contacts burn or worn.
Most likely the starter contacts and plunger need to be replaced. They are common wear items. I rebuilt 3 starters recently and while the 1FZ-FE starter is easier to get to than the 3FE, it is still a bit of a PITA. Parts are available from Toyota, assuming your current starter is OEM.
There are several writeups on the procedure and it's pretty easy to do, but you need to make sure the new contacts lie flat when tightening the bolts. I use a large flatblade screwdriver to put downward pressure opposite the direction of torque when installing. Works every time.
Also, take the time to clean the cylinder walls of the solenoid that the plunger slides into and apply a thin layer of lightweight lubricant to the plunger shaft, pin, and spring.
Take the time to clean the terminal rings on both the motor wire and battery feed line with some fine emery cloth before reassembly.
I've had similar symptoms for at least a year. I have had a couple of instances when the starter was engaged, but seemed to stutter and drop out. I suspect the starter contacts there, but it's so intermittent that seems like it's not the primary issue...
Which is just getting the starter going. Like the OP, I've found that jiggling the key in the ignition will eventually get it going. Here I suspect another reported problem, the ignition switch itself, because the physical jiggling solves the problem and gets a good, clean start 95% of the time. Sometimes it does want to drop out once the starter starts turning but keeping the key turned to start keeps it going.
There are several threads noting that people have wired around the Start position on the ignition switch and used a pushbutton to control Start, solving the problem in lieu of replacing the starter switch, which will also solve the issue there. In fact, I just pulled the trigger this week on a new switch, so will be able to say more in a week or two. Note that the key cylinder and the electrical part of the switch are two separate parts. You want the electrical switch behind the key cylinder. There's contacts in it that become an issue, too, and the key jiggling moves things just enough to get good contact and start.
After that, I'm still expecting to have the more rare (for this truck) starter contact issue, which seems to have poked its head in the door a time or two, but been distinctly different than the usual key-jiggling required to get past the "just a click" (more often, just nothing) issue. With our trucks either pushing or over the 20 year line, there may be multiple issues at play. Diagnose best you can for the major problem, but anticipate you may not completely solve everything with one fix.
Remove the starter, disassemble the solenoid. Use fine grit sand paper to clean the contacts and to clean the contact surface of the plunger. Reassemble and go about your life. I do this every 6 or so months. The contacts get little burs on them and get covered in carbon from electrical arching. Just have to clean those surfaces and you're good for a while.
While I am not averse to getting dirty and assuming this is the problem, I would pay the few dollars for the contacts set and call it done for another ten years or so? Breakdowns rarely happen when parked outside a garage or spare parts shop on a sunny day next to a bar selling cold beers.
More likely pissing down with rain, cold night, kids screaming in the back, significant other screaming "why the **** do we have a twenty year old car?" Dare I say more?
regards
Dave
regards
Dave
Understandable, but after 2 seperate sets of contacts from the stealership doing performing the same way I just started cleaning them at first sign of failure. Most recently I cleaned the transmission mating surface, starter mating surface and added a direct to battery ground wire and this seems to have worked out prolonging the cleaning off contacts. And having had the starter not turn while stopped up snow wheeling I can vouch for it not being opportune, however, with someone holding the key to start and whacking the side of the starter with the tire iron gets it going almost every time. So there is no need to be stranded.
You have been waaaay unlucky my friend, two bad sets from the stealers, having to clean the contacts every six months AND a breakdown in the snow! Good job you had someone with you to help you out, that was a fortunate change of luck.
regards
Dave
regards
Dave
I had pretty much made up my mind that I was rebuilding anything I could since I was taking it off.
jumping on the "it's the starter" bandwagon...
