starting/electrical issue
CO MTNS
The cronology:
Last weeekend: no issues whatsover, running great.
Last Sat: installed lift (850J and 863, with PC ES 9000)
Sunday: Tried to start, had run down the battery during the lift install, so I jumped to no avail, then took the batt. to get charged. Put the battery back in and just clicking from the starter. Ordered new plunger and contacts.
It would start with a knock to the starter with a hammer, but occasionally when I would turn the key to start, it would shut off every piece of electrical equipment in the truck, nothing worked, it was as if someone had disconnected the battery. When this happened, I would disconnect the battery, reconnect and then it would start right up.
This weekend: Took out starter and installed new contacts and plunger. Started right up! The old contacts and plunger were no where near as bad as the ones in Georges write up. Acctually in pretty good condition.
The problem, after it started, it had a rough idle, a little low and stumbling intermittenly, and will occasionally stall if idling too long. Still runs great when you give it some gas, and if you kick the idle up to about 750 rpm with the gas peadal all is smooth and good.
I replaced the main body ground, and the ground to the block, while showing some age isn't corroded. I check all of my inline fuses (Fuse links?) and they all were shinny clean. Battery terminals are regularly cleaned and coated with dielectric grease.
I am at a bit of a loss here? Is there a particular fuse link or inline fuse that would cause this and if so where?
Is there a test procedure I can use to track this bug down?
I need some help from the electrical gurus please. I am leaving for Moab/Canyonlands/Zion this weekend and need to get this fixed!
Truck:
97 Landcruiser
118k
test drive
I only drove it 2 or 3 miles, as I was afraid of having to run home more than a few miles.
Should a little road time fix it? It is idling pretty rough with some stumbles, and stalling intermittently if idled too long.
Thanks,
Like 60wag said the ECU needs to re-learn, so a good drive longer than 2-3 miles is needed. Try that then if the problem persists then hit us with the issue again.
