Starting/Cranking Issues
Knoxville, TN
Been having some issues starting my 2002 LC pretty much since a month after I purchased it back in October. I have done some searches here and typically I see everything from EFI Fuse, Fuel Pump, etc. Before I go down any of those routes and start spending money let me explain what I am experiencing and see if anyone has advice on where I should put my efforts first.
Typically when I go to start it up first thing in the morning (cold engine) it almost always starts up on the first crank. But then when I'm running around town doing errands, it typically will take 2, maybe 3 cranks to start up. Sometimes it will start up on first crank but the majority of times it takes 2-3 after the initial start in the morning. So it seems a warm engine equals more cranks to start.
This morning however, I went to start it up while cold but it wouldn't start up at all. I probably gave it 5-6 tries, but nothing. This has happened maybe 3 times now since I have owned the vehicle. One time I had already driven it and was just trying to leave my kid's soccer game. Every time this has happened I have gone ahead and swapped out the EFI Fuse and it seems to do the trick despite the fuse not appearing to be blown despite some discoloration. That being said, I was under the impression after DMing @medtro that if the immobilizer security light does not flash while the engine cranks, it means it's not the EFI Fuse. My immobilizer security light does not flash when cranking.
I'm a bit stuck. Anecdotally, since swapping out the fuse has worked you'd think it is the EFI Fuse but based on what medtro said and the fact the fuse isn't actually blown, something tells me maybe it's probably more of a fuel thing. Like maybe Fuel pressure bleeding down or perhaps it's just the fuel pump starting to go. I just don't know enough to diagnose it myself.
Where would you start?
Could still be fuse box related. Poor/loose connections in the fuse box are common and can be exacerbated with heat.
Other common issue with long crank times is injector leak down but that would be present after sitting when cold as well.
Next crank no start. Disconnect fuel line from fuel filter. Just release hose from white clip on top of fuel filter. Then pinch green locking clip. As you begin pulling hose end off filter. You should get a spray of fuel, as pressure in fuel line & filter released. If no spray, fuel pump is not working. Most times, if immobilizer light going out, when IG key inserted. It means a bad fuel pump.
