Starter
San Diego
Im currently replacing the starter on my 93 FJ80 and was curious if the car comes with the 1.4kw or 2.2kw starter. Also, I am curious if anyone can provide input on if I should choose the 2.2kw, I take trips to the snow, but it rarely gets under 20 Fahrenheit. Thanks and I appreciate any responses.
Check out this thread it has all the info you need on the different starters. Also if you search 2.2kw starter there are tons of threads.
Good luck. All of them will work. I keep a good spare just in case.
Check out voodu3’s link above and see if you can identify which starter you have. If you have the 2.2kw i’d Rebuild it. If you want a new one go to witsend and grab one of his 2.0kw denso’s.
Witsend also has the 2.2kw rebuild kit if you have that starter already and want to go that route.
