Starter teeth type
Seattle, Washington
So in a replacement starter i purchased has pretty much the same teeth with the exception that the factory teeth have a bevel on the inboard side common to the starter motor, and the replacement does not. Ill try to take pictures. Is it possible the gears are overshooting the flexplate?
The new starter intermittently grinds and this morning was the first time it ran but did not engage the flexplate.
Any ideas?
Denso unit? PM me if you like with your cell # and I'll shoot you pics of the non-OEM starter motor I just pulled. It worked fine but at 237K miles and of unknown vintage I decided to replace it with a reman Denso from Amazon.
The brand name is "Ultima" i believe. I saw the box it came in, but i had other this to do around the house.
There were two options, im not sure which one i got either the 1.4kw or the 2.0kw both 10 teeth and 12volt.
New problem is in the cold mornings 30°f on first attempt to start LC tge bendix (starter to flexplate gear) doesnt make contact. Second attempt makes contact but grinds a little beforeengaging tge flexplate and starts LC.
When its a little warmer...like around 45°f to 50°f it grinds a little then engages on first attempt. Is tgere some lube on the plunger (not the gear portion bendix) i should apply to help it push all the way out?
No, you have a weak solenoid. The Bendix should engage even when it's 0° outside.
have not been impressed with generic reman starters, have replaced several. They often use less reliable parts, don't have the seals, breathers, etc. Have had much better results with Denso reman.
I strongly advise against buying O'Reilly's reman starters and alternators. I have had trouble with both, and they are inferior to reman Denso units from Amazon or Rock Auto, IMHO and experience.
Good luck.
Denso 280-0169 pick your poison, we have a local parts store that carries them. Could try returning the Checker one and see if you get lucky on that lottery?
I used some medium strength thread loc on the mounting bolts, could this interfer with grounding....assuming thats how the starter grounds, thru the mount bolts
Nope, the ground is through the cable on the solenoid.
**Update**
So it turns out what oreilys has the 1.4kw listed as the "standard" starter and the 2.0-2.2kw as the optional model.
Anyways so the 2.0kw starter starts right up with no grinding noise and no free spinning noise due to not engaging the flexplate. The 2.0kw cranks much faster.
We shall see if i have problems in a month or 2. Will let you know.
Ground is made where the starter housing touches the engine block.
**Update**
This is what I have on mine (6 months).
How can one tell if a starter is a factory Toyota unit? I took one off of my truck and am holding onto it in case it is an actual Toyota starter and then I will rebuild it with Toyota parts. However, if it is some cheap aftermarket like I already put on it, then I will return it for the $65 core and buy a Denso unit for future. My son works for O'Reilly and gets a great discount, but I don't want to be in the middle of nowhere when a cheap unit craps out on me. It's not like my Studebaker automatic that I can push start.......
