starter questions
Mace said:
I agree..
However I still need to know if a stock 79 had a internal ballast resistor or not.. That is the main question right now..
There is also the possibility that, like in my case, a PO changed things from the stock setup.
Nah, my cruiser was bone stock when I got it.
Okay, so switching to a different coil is an answer..
But is my starter going to go out and need to be replaced anyway (potential increased voltage draw means....)
This is making my head hurt.
Well, I'm not sure if this is the same one that Pin_head posted or not in the other post but it was in the tech links...it's the dia for a 78....and I don't know if would have changed for a 79.
http://www.yankeetoys.org/documents/wiring_diagram_78_fj40.pdf
It appears the 78 has an external resistor based upon the diagram. Also, FWIW, it has the 12v "start up" only wire coming from the starter up to the coil.
77 was a points type
78 was a semi electronic
79 was the first year of the fully electronic dist..
and my head is spinning...
pretty soon we'll get to the bottom of it...but based on being full electronic...unless they were lagging on the coil conversion...I'd guess no external ballast. I'll check some books tonight to see if a have the 79 diagram. The the spinning will slow down....momentarily.
Also, Dave this diagram for a 71 shows the exact same as my 73 as far as coil, ballast, 12 volt start up only is concerned.
http://www.geocities.com/calcide/fj40wd.html
Todd, I see what you mean.
Only that's not a 71 diagram. For one thing, the 8 fuse fusebox didn't come in until later. 71 has 6 fuses. Also, there is no aux wiring on the ignition for a 71, and that diagram shows it. So I think the external balast resistor was added after 71. The wiring diagrams have had variences from the actual on the ground vehicles in a number of instances, so who knows about that.
Mace,
The only diagram I have at home is in the Haynes...shows it as being the same as the 78. But then again Haynes doen't have the correct diagram shown for my 73 .....somebody here should have a factory diagram...send the pimp a PM.
This is an excellent post and wanted to bring it back up for discussion.
I have a Mallory Unilite distributor and (can't remember the brand) high output coil. My jumper wire is disconnected from the starter and coil. I have a ballast resistor in place. I have no problems with the ignition operation. It starts quickly and runs well.
However, I noticed a few months ago that my ballast resistor gets very hot. Too hot to hold onto. I decided to take the ballast resistor out for a test and found that the ignition fuse in the fuse block gets very hot. I suppose that the high output coil is drawing a quantity of amps just below the capacity of the fuse so it gets hot but does not burn out (at least for the duration of the test, a few minutes). Also, when I bought the distributor from MAF a few years ago, they told me that I could or should open up the spark plug gap some in order to get a better spark and that the distributor and coil combination would support the larger spark. Since a coil will only send enough amperage to the plug to jump a spark, my guess is that a fairly significant amount of amperage is being used to jump the greater spark plug gap thus drawing an excessive amperage from the main ignition circuit.
I may be answering my own question here.
So whether you use a ballast resistor or not (6 volts or 12 volts to the coil) the amperage draw is large enough to heat up either the ballast resistor or the ignition fuse in the fuse block.
Does anyone have any ideas as to what's happening here?
I think I'll run a test by decreasing the spark plug gap back to factory setting. I'll post the results.
Thanks,
James H.
Ballast resistors get hot. It's normal. Super duper high output coils aren't necessary on a 2F, may be less reliable and don't accomplish anything. The stock plug gap is already wide at .040 compared to most engines and opening it up will tend to make the spark less reliable by increasing the voltage necessary to jump the gap and making it more likely that the insulation will break down and it will spark somewhere else.
If you have a high performance engine (supercharged, high compression, etc) then you need an ignition to match the performance requirements. Putting a high performance ignition on a 2F won't change its performance, just like putting a $100 saddle on a $10 horse won't make it run any better.
Does turbocharged count???
Well, I pulled the starter.
Took it down and had it checked out. Apparently it is perfect.
I did however try something interesting tonight. When I turn the key (without a starter) I still lose power (I can hear the dual battery solenoid clicking on and off)
soo... Key issues??
Any other ideas??
Ignition switch 'could' be jacked...
Ohm it out...
Do you have a known good switch assembly around?
Pretty easy to try that out....
Pin_Head said:
Try jumping the coil + with a separate 12V battery first to make sure that it isn't something else before you put a lot of effort in working this out.
You did try this first, right? This would rule our wierd problems with the coil and ignition. Then try jumping it directly from your battery + to the coil +. This will rule out problems with the ingition key circuit.
That is the funny thing... I tried that..
But.. I might have been on the wrong side of the dual battery solenoid..
I am not the brightest sometimes...
Should be..
everything grounded is to bare metal (nothing rusts here)
or it is with 00 welding cable..
I think I need another start switch..
And, when the key is in the "on" position and I use a starter button I still cannot get it to start..
Woodrow, you are an ass for screwing with my sig...
:flipoff2:
