Starter question...
SC
I'm pretty sure my starter is toast, and I need to replace it. I know that there are two different models (based on kW or something). Does it matter which one I have now, if I am going to replace it? I know you have to get the right parts when doing a rebuild, but how about when replacing the whole thing?
Will,
Whats wrong with the starter? usually just changing out the contacts fixes it.
If you go to the FAQ for 80/LX450 sticky thread and scroll down to the maintenance section there is a link to a write-up on replacing the contacts.
I should have elaborated. I replaced the contacts about a year ago. About six months ago, it started acting up again, doing the single click more and more often. About a month ago, it would do the single click, and sometimes make a pop or a small boom and crunch sound when it would finally start. Saturday night, it took a loooong time to get it working, and then I proceeded to bury the truck to the frame in some soupy mud water / mix. I got pulled out by a tractor and drove home with no problem. Since then, no workie, only clickie. :frown:
Sounds like the solinoid. You could replace that and it's much cheaper.
Adding to this starter thread...
Twice now when it has been roughly 0*F outside my truck has gone -cliunk- on the first key turn. It has started each time on the second key turn.
Should I order the contacts/plunger from Cdan now so I have them the next time it thaws?
Soooo, anybody know whether the two starter complete models are interchangeable, or if one has to be replaced by the same model?
to answer your question wob, no, it doesn't matter.
you can replace with either starter.
Thanks, Doug. Just got off of the phone with the Toy dealer that's about half an hour away. They want over 300 bones for a starter. :eek: I might have to go aftermarket (if anyone in town has one) for this one.
Wonder if Cdan can fedex it? :idea:
EDIT: I'll bet the weight of it will make that a no go.
The solinoid is cheaper and easy to replace.
