Starter motor replacement
Honduras
my 40 is barely cranking over and suspect its my starter. Has anyone replaced the motor on one? How much did it run you and is it fairly easy??? Thanks
I did the gear reduction starter from a 60 series, it’s as simple job as you can do.
Clean the connections on your starter ground strap... both end... make sure the connection to the frame is contacting bare metal.
Make sure your battery is fully charged and your positive to starter has good clean connections.
If you’re replacing your starter, I agree, the FJ60 Gear Reduction Starter is the way to go... smaller, more efficient and two wires vice three.
Mine is used and came from Georg (@orangefj45)... Mark (@65swb45) May have one as well.
thanks guys, fixed. although i was unable to install the 60 Gear Reduction Starter this time (being in Honduras, limited resources) I will def swap when i get back to the US. Cheers.
