starter issues
Whitehorse, Yukon
Went to start it, one click nothing.
tried knocking solenoid, nothing.
Pulled starter, checked connections, replaced, went to start, nothing,
Waited a minute, tried again, started, drove home and parked it.
My under the hood connections seem fine, do you think i have a wiring issue, faulty solenoid or should I just get a new starter and solenoid?
Advice appreciated,
Thanks,
Kerry
Advice appreciated,
Thanks,
Kerry
U have a fully charged battery ?
the symptoms u described could indeed be a weak or dead battery
U can have your battery tested at your local Battery warehouse for free
Clean your battery terminals and put them back together with dielectric grease. Clean your negative cable terminal end (the ground) where it attaches to the frame or engine block, reattach it with star washers and dielectric grease. Same for the starter cable.
Q. What is dielectric grease?
A. It is a grease specifically formulated to have high dielectric strength, i.e. high electrical resistance. It should not be used on low voltage applications.
For low voltage applications, use a grease formulated to improve electrical conductivity, such as Ox-Gard.
I have a similar issue, one click and nothing. Brand new battery. Was stuck at a local park, after dark and they were about to lock the gates.. had to push start it. (But got to teach my son how that is done!!)
Got home and she starts right up every turn of the key.
Is there an algorithm for figuring out what is bad? Starter, solenoid, battery or connections?
Hi Jim ,
can u shed any Light on this Product based on first hand experience or by simply reading the label ?
I purchase it at a Local Commercial Marine Parts Supply House
I have had Very Good results so far , but hesitate putting it in my grease gun and going at Zerk Fittings :meh:
it states a Wide range of applications from food service to wheel bearings , Universal Joints , & Chassis lubrication , I interpret that as Tie Rod Ends
as well as Di-Electric Grease o_O
Thanks in advance for your input
Back in the day, when my starter did that, I'd roll underneath and whack it (the starter) with a hammer, or a rock, or my shoe. Just whack the sturdy looking parts of the starter, not the fragile looking bits where the wires go. Usually, the starter worked just fine after that for a month or so. Then whack it again. Then one day I got tired of rolling underneath and bought 2 new brushes for the starter motor from the dealer. Took it apart and shined up the formerly shiny area that the brushes brushed against, put those new brushes in and worked another 10 years or so.
YMMV.
I have one of these in the automotive drawer to go into a spare gear reduction starter that was causing these issues but have not gotten a "round to it" https://www.amazon.com/gp/product/B007FQQURO/?tag=ihco-20
simple rebuild.. like Pighead said.. I wouldn't waste my time rebuilding a non gear reduction starter tho.. they are too heavy to mess with changing. I've tossed (recycled) new ones that have come on donor rigs.
I got a similar kit off eBay, and went to rebuild my starter. Unfortunately, the kit din't fit. I was able to replace the battery side contact and used some sandpaper to smooth out the plunger. No more click, starts every time so far, (knock on wood) . Pretty easy, even for a non- mechanic. If you can get the numbers off your starter, the rebuild kit should work.
^^x2
Be sure your battery ground has clean contact with the starter case and the frame.
All of the above are good things to try.
I had an on-going issue with my ignition switch that caused the same symptoms.
It fixed itself after many years.
Just spent a full day on my bj40 hunting the starter click issue.
Ended up being bad connections at the fusible link near the battery.
Rewired all good
I had a similar issue with my 3B. Turns out my solenoid was getting enough power to actuate the plunger but wouldn’t always spin the motor. It would get stuck in the extended position and I would have to rock the truck back and forth in 3rd gear to free it.
I wired a relay between the starter solenoid and my ignition switch and it cranks much better now and hasn’t gotten stuck. (I believe there is a relay like this from the factory for the 3B, either way it doesn’t hurt)
