Starter fix maybe??? possible?
True, my bad. Time for another cup of coffee.
landtank said:
My understanding is that the EFI relay only interupts the fuel and spark to the engine. With a bad relay the engine turns over but will not start.
Kalawang, if you are re-engineering the truck you're not fixing anything, just compensating.
Landtank,
No I'm not re-engineering. There's a part of the starter that we thought might not be passing enough electriciy and causing intermittent failure. The solution was to clean it up and add some solder. I have 2 starters both of which show the same problem so I apply the idea to one, mount it and see if the starter becomes steady. If it doesn't work, I dismount and think some more.
We've already taken it apart three or more times and re-examined the parts. I've had this problem for about a year or more. One of these days I'll give up and just buy a new starter, but not now. Not yet.
Kalawang
landtank said:
I doubt adding solder to a high current motor as a repair will yield the the wanted results. But who knows.
Landtank,
You're right. It didn't. I'm going to a different repair shop next time I have the time. :mad:
Kalawang
