Last week I replaced the starter contacts (last done June 2005), only one looked slightly worn, the other had two wear spots, not the normal semi-circular pattern. Initially it seemed to correct the non-starting issue. Now what happens is I turn the key all the way to the right, all accessories come on, I'm pretty sure I hear the solenoid clicking but there is no turn over. If I con't to hold the key in the start position or try and rotate the key harder it will start, sometimes it sounds like the battery is weak and sometimes it cranks like it should. I need to have the battery checked (Optima red top).
I have read most of the old posts on starter issues - focusing on roncruiser's case. Is this pointing to the ignition switch or a new starter? Thanks, Nelson
