SST Tool?
I have one. They are about $125 + shipping or so to buy from the only company that supplies them (don't recall the name). I would check if there's a club local to you and see if anyone has one. If not, I'm willing to rent mine for a small fee to help offset the purchase price. PM me if interested.
terrx said:
I learned a trick to use a thick + thin shim on top and thin on the bottom. That gets it pretty close.
So what's the reasoning for the "trick"?
I don't see why this would be any better than guessing about any other combination of shims.
Getting the preload right isn't a problem. Getting the spindle bore concentric with the seal bore is the tricky part that the SST does.
Don't know the reasoning. I can imagine that the Toyota plant(s) that made FJ40's could have had (eventually) an accurate manufacturing process that avoided adjusting every axle hub that came off the assembly line individually. Just a guess tho.
If the manufacturing tolerances were good enough, Toyota wouldn't have bothered with shims or fitting them.
jackbrad said:
Is this process covered in the FSM?
Yes, in detail.
I would think that someone with a lathe could make their own tools, whether or not it would be worth the $125 savings is a different question.
