SST Information
Lakehouse
I have been searching the previous posts regarding SST's. I am about to start the rebuild on my 75 FJ-40 restoration and want to have all the necessary tools prior to starting (complete rebuild so I imagine that almost every SST for the vehicle will come into play at some point).
What are the SST's that would be considered absolutely necessary to have on hand as there is no alternative tool workaround?
Which SST's have members figured out alternate replacement tools that work as well?
Thanks.
Yep, I found that site in my search (www.otctools.com) as well as the www.toyota.spx.com site.
I was just wondering which tools were absolutely necessary to perform work on the rebuild so that I can concentrate my resources/money towards those tools and then use some of the workarounds like the PVC pipe seal driver instead of the more expensive SST's where I can.
You will need to see if Mark W. or Poser chime in. I'm sure they don't need or use any SST's :-) but could tell you which ones you might need...
There is usually a work-a-round for any SST if your patient
I used the flame wrench frequently in getting the thing apart. I guess what I really need to know is about the SST for the rebuild of the engine, transmission, and the axles.
