SR caster angle
i understand setups are different but not that much. Many people have reversed the springs and done a SR in this same fashion. I mocked up the stock setup and then the SR with spring flip and the difference was 12 degrees. I would assume this would add 12 degrees of caster unless i relocate my spring perches?
Jetboy said:
Not trying to hyjack, but what would happen with too much caster?
From what little I understand: Positive caster tilts the steering axis backwards at the top so the tire contact patch is centered slightly ahead of the pivot point. Turning causes a slight increase in camber (wheel gets tilted out of the vertical) which helps in cornering. But the tendancy is for the weight of the vehicle to push the wheel back to vertical (minimum camber) and cause the truck to go straight.
There are other factors too. For example, caster also lowers the axle slightly so turning raises the axle and gravity tends to make it go back straight. (This is really noticeable on the bicycles I've owned.)
Ackerman geometry allows the inner wheel to turn tighter around a corner than the outer wheel since they're traveling through different radii (!). I think this reduces scrub (tire being scraped sideways), and reduces the tendancy to over- or understeer. Early vehicles don't have Ackerman geometry. Not sure which Cruisers do and don't.
With way too much caster I think steering effort would be noticeably higher and tire wear would increase a lot. The pinion angle would also be severe. If I ever get around to SR I will likely move the perches, which means another cool project for my new welder.
HTH, theo
HTH, theo
Nice explanation, well said. In other words your steering and handling get's fawked. :D
If you end up with +12* caster your pinion is going to be pointed down severly which will cause some pretty severe front d-shaft & u-joint issues. Thus the reason for a cut and turn. Mock everything, measure not twice but three times so you can give the person who's doing your C&T the right info.
hey, I replied to your pm..
One other thought was that, if youre having someone do the c&t, you could prep the axle, figure out where you want your pinion, tack the spring pads, and then take it off and cut. The dude doing the c&t will be able to determine where the baseline is for the castor.
-Dustin
You shouldn't need to cut and turn with just a normal SR.
Just relocate the perches to get a pinion angle parallel to that of the tcase output, and a caster angle of 1 or 2 degrees.
A C&T would be necessary if one was going to point the pinion at the tcase, or desired large amounts of caster for large tires.
