My last OME (trooper) setup squeaked badly. This time I used silicon grease to remedy Also, I used to have poly sway bushings. Those things squeaked so bad, I had to add zerks to mounts.
^^Take a look at your rear sway bar link bracket. Mine was slightly bent and just a touch loose where the bracket connects to the frame. It squeaked like crazy.
This thread has been going for 7 years.....crazy.
^same as above. Let us know! Mine drives me nuts.
Klaus. Do you have enough slop in the u-bolt that you can loosen and let it come back down? The first time I jacked my truck with mine it did the same. But I could feel mine with my feet in my floorpan.
Short story:
I'm going to try that. Seems like I'm constantly adjusting them.
Long story:
I could hear a weird squeak that I assumed was my drivers door due to the location and sound. In an attempt to solve that, I opened the door while driving to discover that the squeak was even louder. And coming from right where the slider mount is.
The mounts on my WKORs seem off. No matter how I adjust them, they seem to be almost touching the pinch weld upfront and a mile away in the rear. And the middle mount touches the underside of the body. I'm going to try loosening them up and tightening the top bolts first, then the bottom. The theory is that the u-bolts triangulating at the top slightly will stop them from creeping up. If that doesn't work I might just weld them on.
Hi-Jack over.
After driving around with the door open today, a lot of my squeak seems like its the slider mount touching the body of the cab.
Gotcha. Yeah mine is definitely Coming from both FPS and rear axle assembly somewhere. Very hard to narrow down both of their exact locations when they both make noise.
