Squealing Pig in Reverse
El Dorado National Forest
So this Tractor must have a pig stuck under the LC. All maintenance items up to date. This is after driving with an improperly installed propeller shaft. So after warm up, in Reverse (the loudest) there is a constant high pitched longish chirp. Shifting from Reverse to Drive it makes a whoop sound. See videos below.
Squeak or Whoop when shifting
Constant Squeal or Chirp
I'm not really hearing what you're describing as a Pig Squeal.
I hear the screech as soon as you shift from R to D, but that is very typical and is usually brakes as the suspension changes position. No problems there.
I don;t hear anything but a ton of "noise" on the second video, but cannot pinpoint anything you're trying to get across.
Ok. It’s just the first I heard that whoop noise. The whole time I’ve owned the truck. Also happens on take off intermittently.
The noise on the second video is only in reverse. The turning constant chirping of such, very new noise. I was thinking transmission filter is all clogged, Unsure though.
Drive shaft installed in phase or out isn't going to break anything. Some have the drive shafts installed as per factory service manual and some dont. Which ever way results in no vibrations is the groovy one, man.
The chirping or whatever doesn't come through for me on my phone.
