Has anyone added the extra check ball to their valve body per TSB TC001-98?
https://forum.ih8mud.com/showpost.php?p=2748471&postcount=24
I have this issue and my transmission serial number is within the affected range. It annoys me enough that I'm planning on performing this service in a couple of weeks (imagine a honking sound every time you shift from reverse to park or reverse to neutral). There are a lot of bolts to remove and replace (65 or so) and a few bits here and there, but it doesn't seem to be a terribly difficult job.
I've done all the of maintenance and repairs on two 80 series cruisers over the last 8 years so I'm no stranger to a wrench and I have all the Toyota service manuals, but I've never done any kind of transmission work other than fluid changes and flushes. I'm mostly concerned with removing the valve body and opening it. Can anyone offer any insight into this job? There seems to be a check ball body and spring that may fall out when I remove the valve body, will it? Is there anything else that will want to spring or fall out when I remove the valve body or separate the halves?
Thanks in advance for any words of wisdom.
Keywords: A343f, trans, transmission, valve body, chatter, squealing, reverse
