Squealing Mean Green alternator
Oregon
91 fj80. New MG alternator squeals, instructions say another belt may be needed if it squeals. Anyone know which belt I need to buy? Thank you.
Also, I don’t really care what your opinion of MG is, I keep the old one close by 😁.
The belts age is unknown so assume ancient. It didn’t make a sound prior to replacement of alt so I think it’s the correct size. Haven’t measured the pulley or compared. Unsure of how to check tension accurately. Didn’t make a noise at first but, after a 500 mile trip yesterday it’s very noticeable.
I appreciate the part number. I just didn’t want to buy a couple if I needed something different for this alt. I’ll check out the pulley sizes later.
It probably has a smaller pulley to help it put out more amperage at idle. Belt could be slipping
Just check the tension with your finger, will be noticeable if too loose.
That’s pretty much how I’ve tested it. And that would make sense about the pulley. I’ll let you know later.
Easy belt confirmation; with it squealing, spray a little water on the belt. If the noise goes away or is significantly reduced, the belt is the problem, if not look elsewhere.
