I know discount tire and other have this information at hand, however what happened to pie x diameter…?Couple notes that might simplify what you're looking for:
- 4.88s aren't a factor. Speedo is wheel speed from the ABS sensors and not the transmission output shaft.
- Tire manufactures often include "revolutions per mile" for each tire size. Since they're using the same methodology between tire sizes, the correction factor is simply a ratio between the two tires sizes in question.
Saying this it is worth noting that accurate diameter is also on the tire websites so you may as well do what you say!
