Springover axles
Status
Not open for further replies.
Hull, Mass
Bought these last Fall and dont need them. Front disks and already set up for a traction bar.
$400.00 firm
Yes, they're for a 40. Sorry for the confusion. I have a few pics I just took but the light is pretty low. Here they are in all their glory. :)
The gear ratio is 4.10, I thought all disk axles are fine spline. They have Warn hubs.
SOrry should have been more clearer. I meant the pinion.
Have the knuckles been C&T?
The knuckles were not cut and turned. I will have to check on the pinion splines.
I have never been to the GSMTR. I have read about it in the past.
Bump. Axles can be used spring under as well! Front disks...
wonder if these will do the trick for my 67FJ40...trying to convert from drum brakes to disc brakes all around....may be interested if this will work...
They will. It is a really decent upgrade from the axle you already have on there. Stronger birfields and disks.
hmmm...interesting...now the hard part...getting them over here to NC...how much would you figure shipping to 28075??..thanks...
Status
