Sooooo ..... The stink bug of J's finally got to me, so I made some spring spacers. The way my shocks are set up with the previous 2" bumsptop spacers were no where near fully compressed. I measured the front fender to tire, and rear fender to tire and front to back was out just under 1.5". So, out come thre springs, out come the spring buckets, and work begins. I couldn't get the darn nuts off the bumpstops, so I ended up cutting my bumpstop spacers 1/2 way through to cut the bolt. Nothing a little welding couldn't fix. I'm not using them anyway - since the spring spacers now space the bumptops down 1.375" - but figure someone might get some use out of them someday.
I thought I had enough steel, but I didn't so I had to run to the local steel yard, get some drop off. Minimum purchase was 34lbs for $10.50, so I got about 4 or 5 times the steel I needed, but I'm sure I'll find some use for the rest of the plate.
The one mistake I made from listening to a friend and not thinking was I pounded out the studs. This was a mistake cause since the spring needs to sit flat, you can't use bolts on them.... well, since I don't plan on going back, nothing the welder can't fix!!!
I of course do not have a plasma cutter, so, getting the shape takes a little time.
Here's the steps....
1. Put the spring cone / perch/ whatever you call it, on the plate steel.
2. Drill the holes.
3. Mark the pattern.
4. Rough cut the pattern with cut off wheel on the old dewalt grinder.
5. Bolt the rough cut plate on the spring cone and switch over to the flapper disk to match the shape.
6. Cut 2.5" square stock w/ the chop saw - go nice and slow to get a good square cut.
7. Weld the square stock to one plate.
8. Throw some bolts through both sets of holes to line everything up and weld the top on.
9. Weld some nuts to the top plate.
Now, if I hadn't knocked out the studs (and thrown them out before I realized I needed them), I wouldn't have had to weld the plates to the spring cone. Oh well. If I was to do it again I'd probably also weld bolts on rather than nuts, it'd just make mounting easier, not that it's going ot be hard, but easier is always better.
You'll have to forgive all the splatter - I switched welders, and haven't hooked up a tank yet so this is all flux core'd, which is new to me, it's o.k. and has some advantages, especially when trying ot get that top plate welded on as there isn't alot of room between the plates. I thought about taking some 1" wide strap and running it the whole way around to make it look solid, but that's too much work, and isn't going to make it work any better. The whole thing looks better after some Duplicolor spray can bedliner - I love that stuff - use it everywhere I'd normally use black spray paint - hides stuff, and last well...
Steel $10
3 Cutt-off wheels $6.00
1 Flapper disk $5
Being able to do this stuff yourself rather than buying it - Priceless
enough text, here's some photos...
2. Drill the holes.
Steel $10
1 Flapper disk $5
