Spring Question
I was curious if I could only install and use 4" slee springs with nothing else (castor correction, etc). What's the 'minimun' I would need? I tried searching, but I couldn't find exactly what I was looking for. Thanks! :)
probably shocks, swaybar & brake line drop brackets, bump stop drop brackets, double cardan shaft, and yes...some sort of caster correction. probably could toss in some adjustable panhards...but those are optional.
...so yes, there really is no minimum. if anything at least get some plates cause youll most likely need the CC.
I would highly recommend caster correction, I have much less lift, and my handling was twitchy, nearly white knuckle on the freeway... I was uncomfortable letting anyone else drive it... Just did caster correction and handles like a dream. With a 4" lift, I can only imagine how many more times I would have white knuckles, if there were no caster correction.
What he said. Same experience here....
You need shocks and longer brake lines. IMO swaybars are not needed, but if you insist on running them, you would need the brackets. CC is something you can do later, but it does make for an eventful drive. I'm approx. 5" of lift with no CC... It's all over the place, but you kinda get used to it. :flipoff2:
